very slow loading
stolzmedia
stolzmedia posted this 04 May 2015
Why does it take so long for themler to load? It's not my Internet connection, I've tried to load themler at home and at work and it is so slow. I am trying to finish a layout in time for production and every time I save my changes it take 15-20min to reload. How do I get Themler to load faster after saving changes?
19 Comments
Stagger Lee posted this 04 May 2015
Yesterday and today was slow. Some server glitch and problems. Not it is fast as before. At least for me.
Support Team posted this 05 May 2015
Thank you for reporting about the issue.
Does it still persist today?
Ivan
Hi, Thank you for reporting about the issue. Does it still persist today? Thanks, Ivan
stolzmedia
stolzmedia posted this 05 May 2015
Ivan
Yes, very slow loading and saving.
> Hi, > > Thank you for reporting about the issue. > Does it still persist today? > > Thanks, > Ivan Yes, very slow loading and saving.
Support Team posted this 06 May 2015
Our engineers investigated your issue and told me that delays are mostly caused by your internet connection speed.
Here are some results from our tests:
Total save time - 112 sec.
Time of exact Themler operations - 5.7 sec.
Thus, the difference of 106.3 sec is caused by the net issues.
As a possible solution I would recommend you to install Themler theme on your WP localhost and let us know if the issue still persists.
Ivan
Hi, Our engineers investigated your issue and told me that delays are mostly caused by your internet connection speed. Here are some results from our tests: Total save time - 112 sec. Time of exact Themler operations - 5.7 sec. Thus, the difference of 106.3 sec is caused by the net issues. As a possible solution I would recommend you to install Themler theme on your WP localhost and let us know if the issue still persists. Thanks, Ivan
david.blyth
david.blyth posted this 04 August 2015
I am using the Desktop version and I must say that it's exceedingly slow, it will take hours to design anything at this rate. Why can't the desktop version save locally as opposed to the cloud, not everyone has fast connections.
Support Team posted this 06 August 2015
Sorry for the delay.
The Desktop version saves files locally and uses local repository of controls, etc. It uses less traffic than basic Themler theme installed in local CMS.
But it's still needs internet to connect protection server, for example. We're still working on improving Desktop version and plan to make it more offline in the future.
Hello Sorry for the delay. The Desktop version saves files locally and uses local repository of controls, etc. It uses less traffic than basic Themler theme installed in local CMS. But it's still needs internet to connect protection server, for example. We're still working on improving Desktop version and plan to make it more offline in the future. Thank you, Olivia
mmp
mmp posted this 14 August 2015
The speed is still an issue. It takes about 10 -15 min. to save (online) and sometimes the browser refreshes when making a design change. That can take up to 5 min.
I just made some changes to a page content and did not save while working for about 40 min (due to the slow saving time. Upon saving I got a
"browser error, please refresh cache" - Then everything was lost.
The speed is still an issue. It takes about 10 -15 min. to save (online) and sometimes the browser refreshes when making a design change. That can take up to 5 min. I just made some changes to a page content and did not save while working for about 40 min (due to the slow saving time. Upon saving I got a "browser error, please refresh cache" - Then everything was lost.
Support Team posted this 15 August 2015
Hello Stephan,
please create a new private topic http://answers.billiondigital.com/Topic/Create?private=1 and
- provide us with TeamViewer access to your computer if you have got delay with Themler Desktop version;
- access credentials to CMS admin back end if Themler Online version is so slow.
Thank you.
Hello Stephan, please create a new private topic http://answers.billiondigital.com/Topic/Create?private=1 and - provide us with TeamViewer access to your computer if you have got delay with Themler Desktop version; - access credentials to CMS admin back end if Themler Online version is so slow. Thank you. Regards, Aileen
roberto.torres.aguayo
roberto.torres.aguayo posted this 02 September 2015
i have the same problem ... i downloeaded the desktop version and still it takes more than 2 minutes to load.
is there a fix?
i have the same problem ... i downloeaded the desktop version and still it takes more than 2 minutes to load. is there a fix?
Support Team posted this 03 September 2015
Please provide more information. Does Themler loads 2 minutes every time or only once at first run?
Please note, that at first run Themler loads and caches its files from Internet, in order to work with them locally.
Themler Support Team
Please provide more information. Does Themler loads 2 minutes every time or only once at first run? Please note, that at first run Themler loads and caches its files from Internet, in order to work with them locally. Thanks, Themler Support Team
roberto.torres.aguayo posted this 04 September 2015
hi!!
the first time it takes a long time to run,
then every time I make a copy (save as and re-open (creating a backup)) it takes time to Open the file....
hi!! the first time it takes a long time to run, then every time I make a copy (save as and re-open (creating a backup)) it takes time to Open the file....
me321
me321 posted this 28 September 2015
Themler is always slow in my case. I use the desktop application, the CMS version is too slow to be workable.
It takes very long to load after making a layout change. It also takes long to switch between layouts. Renaming a region takes long and saving too is a good long wait.
It's really a drag on productivity. My connection is fine and my machine is fast.
Themler is always slow in my case. I use the desktop application, the CMS version is too slow to be workable. It takes very long to load after making a layout change. It also takes long to switch between layouts. Renaming a region takes long and saving too is a good long wait. It's really a drag on productivity. My connection is fine and my machine is fast.
Support Team posted this 29 September 2015
@Roberto,
the Themler loads slowly first time because the the files should be uncompressed and about 30 mb should be downloaded. The subsequent Themler loads should be faster.
@me321,
please create the log file following the steps http://answers.themler.com/articles/13879/themler-desktop-troubleshooting#debug_mode and attach it here.
Hello, **@Roberto,** the Themler loads slowly first time because the the files should be uncompressed and about 30 mb should be downloaded. The subsequent Themler loads should be faster. **@me321,** please create the log file following the steps http://answers.themler.com/articles/13879/themler-desktop-troubleshooting#debug_mode and attach it here. regards, Aileen
AgapeSOUL
AgapeSOUL posted this 14 January 2016
I just downloaded it today. Internet speed is 24Mbs - so it can't be the internet. It loads slow, saves slow and closes slow...
Support Team posted this 14 January 2016
Hi Sucorra Dae,
Please feel free to create new private ticket and provide us with all necessary details here.
Ivan
Hi Sucorra Dae, Please feel free to create new private ticket and provide us with all necessary details here. Thanks, Ivan
jessepelayo
jessepelayo posted this 26 February 2017
I just bought Themler. I have to say that this is extremely SLOW. There is no way to use the program without getting frustrated on the lag.
Please provide a fix.
Hi, I just bought Themler. I have to say that this is extremely SLOW. There is no way to use the program without getting frustrated on the lag. Please provide a fix.
Support Team posted this 01 March 2017
Hello jessepelayo,
please submit new private topic where provide access to your WP admin back end . We need to check your theme more closely.
Hello jessepelayo, please submit new private topic where provide access to your WP admin back end . We need to check your theme more closely. regards, Aileen
David Lynch
David Lynch posted this 01 September 2017
I am now in my eighth month of my Themler license, or rather, Artisteer one year update. I have not been able to use Themler to create a single theme because it is so slow.
Artisteer, which I used to love, is virtually obsolete because businesses want that BIG one page look that Themler seems to promise to produce. The site designs that Artisteer produces, are now considered old school. When I show people Artisteer sites that I used to be very proud of, I get a look like "that's all you got?"
I understand you are working within the constraints of Wordpress (in my case) or other CMSs, but really, this is really impossible to use. No matter how many times I start and restart, I just can't get it to run. $60 lesson I guess. I will wait a couple of years to upgrade as development of this promising product seems painfully slow. I'm sure you are excited about your product, and I hope to use it again sometime.
I am now in my eighth month of my Themler license, or rather, Artisteer one year update. I have not been able to use Themler to create a single theme because it is so slow. Artisteer, which I used to love, is virtually obsolete because businesses want that BIG one page look that Themler seems to promise to produce. The site designs that Artisteer produces, are now considered old school. When I show people Artisteer sites that I used to be very proud of, I get a look like "that's all you got?" I understand you are working within the constraints of Wordpress (in my case) or other CMSs, but really, this is really impossible to use. No matter how many times I start and restart, I just can't get it to run. $60 lesson I guess. I will wait a couple of years to upgrade as development of this promising product seems painfully slow. I'm sure you are excited about your product, and I hope to use it again sometime.
Support Team posted this 04 September 2017
I have seen the message with the same sense in other case. I have replied there about the possible reasons of such slow performance. Hope that it will be solved.
Hi, I have seen the message with the same sense in other case. I have replied there about the possible reasons of such slow performance. Hope that it will be solved. Sincerely, Hella
