Creating a drop down text box
Mark Holland
Mark Holland posted this 04 January 2017
Hi All,
I am trying the best way to create a dropdown text box like this site http://www.licencecheck.co.uk/
When you click on the read more it opens up a new lot of text.
Is this possible in themler or do i need to use a wordpress plugin.
Thanks in advance.
Mark
Hi All, I am trying the best way to create a dropdown text box like this site http://www.licencecheck.co.uk/ When you click on the read more it opens up a new lot of text. Is this possible in themler or do i need to use a wordpress plugin. Thanks in advance. Mark
Mark Holland
Solved Sort of
Solved Sort of
Support Team posted this 05 January 2017
There is no such option in Themler so I'm glad that you have found a solution.
Hi, There is no such option in Themler so I'm glad that you have found a solution. Sincerely, Hella
Mark Holland
Mark Holland posted this 05 January 2017
I started another case, can you check it its titled "Read More error in woocommerce"
In woocommerce i have added some text to the description for the categaory, but it displays the complete text and no read more button.
here is the enquiry:
I have used a read more tag in this page on my site but it does not work, i am using the category descriptiuon in woocommerce.
http://www.firewood2go.co.uk/product-category/kiln-dried-logs/
Here is the code:
<strong>Kiln Dried Logs – Fire logs for Sale!</strong>
Kiln Dried Logs are the most efficient logs for wood burning stoves and open fireplaces. Thanks to their low moisture content of less than 20%, they produce a fast, efficient heat with an attractive roaring flame – buy kiln dried logs from firewood2go.co.uk
<!--more-->
Our Kiln dried firewood is cleaner than seasoned wood and the low moisture content means it is lighter, easier to carry and will not clog up your chimney , woodburner, chimenea or other appliance with excessive deposits of soot.
At firewood2go.co.uk we have a range of high quality Kiln Dried wood for sale, which burn for up to three times longer than unseasoned wood. Choose from our mixed bag of hardwood which is made up of alder, ash, birch or oak logs – alternatively we can supply the best hardwood firewood logs for sale on the market – our European white birch –almost too attractive to burn!
Our logs are dried through a purpose built wood kiln which results in less residual moisture being retained so when they burn they reach a higher temperature quicker.
The logs are easy to light, long lasting and can be burnt immediately as no extra drying time is needed.
<strong>Why should you buy Kiln dried logs?</strong>
Our kiln dried wood produces a long, hot and efficient fire which burns with a bright, natural flame and creates an aromatic and warm atmosphere around any fireplace. Less energy is required to burn off any residual moisture and sap held within the logs and as a result more heat is produced and far less soot or tar builds up inside of your fireplace or appliance.
Because <a href>kiln dried l</a>umber burns so hot, less wood is used to achieve the same heat output from other seasoned logs. Using kiln dried firewood instead of seasoned wood will save you a lot of money in the long run.
Kiln dried wood from firewood2go.fo.uk is the number 1 choice of firewood for use on any wood burner, open fire, multi-fuels stoves, firepits, chimeneas, and pizza ovens.
<strong>Hardwood firewood logs for sale – look no further than firewood2go.co.uk!</strong>
thanks
I started another case, can you check it its titled "Read More error in woocommerce" In woocommerce i have added some text to the description for the categaory, but it displays the complete text and no read more button. here is the enquiry: Hi, I have used a read more tag in this page on my site but it does not work, i am using the category descriptiuon in woocommerce. http://www.firewood2go.co.uk/product-category/kiln-dried-logs/ Here is the code: &lt;strong&gt;Kiln Dried Logs – Fire logs for Sale!&lt;/strong&gt; Kiln Dried Logs are the most efficient logs for wood burning stoves and open fireplaces. Thanks to their low moisture content of less than 20%, they produce a fast, efficient heat with an attractive roaring flame – buy kiln dried logs from firewood2go.co.uk &lt;!--more--&gt; Our Kiln dried firewood is cleaner than seasoned wood and the low moisture content means it is lighter, easier to carry and will not clog up your chimney , woodburner, chimenea or other appliance with excessive deposits of soot. At firewood2go.co.uk we have a range of high quality Kiln Dried wood for sale, which burn for up to three times longer than unseasoned wood. Choose from our mixed bag of hardwood which is made up of alder, ash, birch or oak logs – alternatively we can supply the best hardwood firewood logs for sale on the market – our European white birch –almost too attractive to burn! Our logs are dried through a purpose built wood kiln which results in less residual moisture being retained so when they burn they reach a higher temperature quicker. The logs are easy to light, long lasting and can be burnt immediately as no extra drying time is needed. &lt;strong&gt;Why should you buy Kiln dried logs?&lt;/strong&gt; Our kiln dried wood produces a long, hot and efficient fire which burns with a bright, natural flame and creates an aromatic and warm atmosphere around any fireplace. Less energy is required to burn off any residual moisture and sap held within the logs and as a result more heat is produced and far less soot or tar builds up inside of your fireplace or appliance. Because &lt;a href&gt;kiln dried l&lt;/a&gt;umber burns so hot, less wood is used to achieve the same heat output from other seasoned logs. Using kiln dried firewood instead of seasoned wood will save you a lot of money in the long run. Kiln dried wood from firewood2go.fo.uk is the number 1 choice of firewood for use on any wood burner, open fire, multi-fuels stoves, firepits, chimeneas, and pizza ovens. &lt;strong&gt;Hardwood firewood logs for sale – look no further than firewood2go.co.uk!&lt;/strong&gt; thanks
Mark Holland
Mark Holland posted this 06 January 2017
still no answer :(
still no answer :(
Support Team posted this 10 January 2017
Hello Mark,
I'm very sorry for delay.
Please refer to my response in topic http://answers.themler.com/questions/114648/read-more-error-in-woocommerce
Hello Mark, I'm very sorry for delay. Please refer to my response in topic http://answers.themler.com/questions/114648/read-more-error-in-woocommerce Regards, Aileen
