Read More error in woocommerce
Mark Holland
Mark Holland posted this 04 January 2017
I have used a read more tag in this page on my site but it does not work, i am using the category descriptiuon in woocommerce.
http://www.firewood2go.co.uk/product-category/kiln-dried-logs/
Here is the code:
<strong>Kiln Dried Logs – Fire logs for Sale!</strong>
Kiln Dried Logs are the most efficient logs for wood burning stoves and open fireplaces. Thanks to their low moisture content of less than 20%, they produce a fast, efficient heat with an attractive roaring flame – buy kiln dried logs from firewood2go.co.uk
<!--more-->
Our Kiln dried firewood is cleaner than seasoned wood and the low moisture content means it is lighter, easier to carry and will not clog up your chimney , woodburner, chimenea  or other appliance with excessive deposits of soot.
At firewood2go.co.uk we have a range of high quality Kiln Dried wood for sale, which burn for up to three times longer than unseasoned wood.  Choose from our mixed bag of hardwood which is made up of alder, ash, birch or oak logs – alternatively we can supply the best hardwood firewood logs for sale on the market – our European white birch –almost too attractive to burn!
Our logs are dried through a purpose built wood kiln which results in less residual moisture being retained so when they burn they reach a higher temperature quicker.
The logs are easy to light, long lasting and can be burnt immediately as no extra drying time is needed.
<strong>Why should you buy Kiln dried logs?</strong>
Our kiln dried wood produces a long, hot and efficient fire which burns with a bright, natural flame and creates an aromatic and warm atmosphere around any fireplace. Less energy is required to burn off any residual moisture and sap held within the logs and as a result more heat is produced and far less soot or tar builds up inside of your fireplace or appliance.
Because <a href>kiln dried l</a>umber burns so hot, less wood is used to achieve the same heat output from other seasoned logs. Using kiln dried firewood instead of seasoned wood will save you a lot of money in the long run.
Kiln dried wood from firewood2go.fo.uk is the number 1 choice of firewood for use on any wood burner, open fire, multi-fuels stoves, firepits, chimeneas, and pizza ovens.
<strong>Hardwood firewood logs for sale – look no further than firewood2go.co.uk!</strong>
Hi, I have used a read more tag in this page on my site but it does not work, i am using the category descriptiuon in woocommerce. http://www.firewood2go.co.uk/product-category/kiln-dried-logs/ Here is the code: ------------------------------------------------------------------- &lt;strong&gt;Kiln Dried Logs – Fire logs for Sale!&lt;/strong&gt; Kiln Dried Logs are the most efficient logs for wood burning stoves and open fireplaces. Thanks to their low moisture content of less than 20%, they produce a fast, efficient heat with an attractive roaring flame – buy kiln dried logs from firewood2go.co.uk &lt;!--more--&gt; Our Kiln dried firewood is cleaner than seasoned wood and the low moisture content means it is lighter, easier to carry and will not clog up your chimney , woodburner, chimenea  or other appliance with excessive deposits of soot. At firewood2go.co.uk we have a range of high quality Kiln Dried wood for sale, which burn for up to three times longer than unseasoned wood.  Choose from our mixed bag of hardwood which is made up of alder, ash, birch or oak logs – alternatively we can supply the best hardwood firewood logs for sale on the market – our European white birch –almost too attractive to burn! Our logs are dried through a purpose built wood kiln which results in less residual moisture being retained so when they burn they reach a higher temperature quicker. The logs are easy to light, long lasting and can be burnt immediately as no extra drying time is needed. &lt;strong&gt;Why should you buy Kiln dried logs?&lt;/strong&gt; Our kiln dried wood produces a long, hot and efficient fire which burns with a bright, natural flame and creates an aromatic and warm atmosphere around any fireplace. Less energy is required to burn off any residual moisture and sap held within the logs and as a result more heat is produced and far less soot or tar builds up inside of your fireplace or appliance. Because &lt;a href&gt;kiln dried l&lt;/a&gt;umber burns so hot, less wood is used to achieve the same heat output from other seasoned logs. Using kiln dried firewood instead of seasoned wood will save you a lot of money in the long run. Kiln dried wood from firewood2go.fo.uk is the number 1 choice of firewood for use on any wood burner, open fire, multi-fuels stoves, firepits, chimeneas, and pizza ovens. &lt;strong&gt;Hardwood firewood logs for sale – look no further than firewood2go.co.uk!&lt;/strong&gt; -------------------------------------------------------------------------------------------------
8 Comments
Mark Holland
anyone??
anyone??
Mark Holland
Mark Holland posted this 06 January 2017
still no answer :(
still no answer :(
Mark Holland
Mark Holland posted this 10 January 2017
come on support 5 bloody days this is ridiculous
Support Team posted this 10 January 2017
Hello Mark,
I'm terribly sorry for delay in response.
The Read More tag does not work in this case, the Product Description control which is used to output product description does not support this tag.
I'll contact developers about possible solution and will let you know.
Hello Mark, I'm terribly sorry for delay in response. The Read More tag does not work in this case, the Product Description control which is used to output product description does not support this tag. I'll contact developers about possible solution and will let you know. regards, Aileen
Mark Holland
Ok thanks
I am using a plugin for now but Its a positive SEO addition.
Thanks Mark
Ok thanks I am using a plugin for now but Its a positive SEO addition. Thanks Mark
Support Team posted this 10 February 2017
Hello Mark,
On the Products template the Product Short Description is used (this control is not designed to support the WP More tag), the Full Product Description is used on the Product Details template. So you may create custom link or button on the Products template which point to selected product details with full description.
To do it add CMS Code control and put there the code
<a href="<?php echo $product_view['link']; ?>">View Product Details</a>
To style this link as Themler button please use the following code:
<a href="<?php echo $product_view['link']; ?>" class="bd-button">View Product Details</a>
Hello Mark, I'm terribly sorry for delay in response. On the Products template the Product Short Description is used (this control is not designed to support the WP More tag), the Full Product Description is used on the Product Details template. So you may create custom link or button on the Products template which point to selected product details with full description. To do it add CMS Code control and put there the code <a href="<?php echo $product_view['link']; ?>">View Product Details</a> To style this link as Themler button please use the following code: <a href="<?php echo $product_view['link']; ?>" class="bd-button">View Product Details</a> regards, Aileen
mubeenchonline
mubeenchonline posted this 12 April 2024
Authorized appliance service is essential for ensuring the longevity, efficiency, and safety of your household appliances. By prioritizing regular maintenance, choosing the right service provider, and embracing technological advancements, you can enjoy hassle-free operation and peace of mind. Remember to address appliance issues promptly, follow preventive maintenance tips, and seek professional assistance when needed. Together, we can prolong the lifespan of our appliances, reduce energy consumption, and contribute to a sustainable future.
[Authorized][1] appliance service is essential for ensuring the longevity, efficiency, and safety of your household appliances. By prioritizing regular maintenance, choosing the right service provider, and embracing technological advancements, you can enjoy hassle-free operation and peace of mind. Remember to address appliance issues promptly, follow preventive maintenance tips, and seek professional assistance when needed. Together, we can prolong the lifespan of our appliances, reduce energy consumption, and contribute to a sustainable future. [1]: https://www.reliable-appliance-service.com/
mubeenchonline
mubeenchonline posted this 20 June 2025
In today’s fast-paced world, appliances like refrigerators, washing machines, ovens, and dishwashers are the backbone of any modern home. When these essential appliances break down, it can cause major disruptions. That's why choosing an authorized ge refrigerator repair is not just a smart move—it’s the safest one.
In today’s fast-paced world, appliances like refrigerators, washing machines, ovens, and dishwashers are the backbone of any modern home. When these essential appliances break down, it can cause major disruptions. That's why choosing an [authorized ge refrigerator repair][1] is not just a smart move—it’s the safest one. [1]: https://www.authorized-appliance.com/
