Buttons switches the slider
milu.cernochova
milu.cernochova posted this 12 January 2017
I have a complicated question.
How do I create the buttons that switches the slider? I have two columns, in first is a slider, in second is three buttons next to each other. Slider switches depending on which button I press.
Thank you.
Hello, I have a complicated question. How do I create the buttons that switches the slider? I have two columns, in first is a slider, in second is three buttons next to each other. Slider switches depending on which button I press. Thank you.
Support Team posted this 12 January 2017
That can be done with the custom code. Or you can find the appropriate plug-in for your CMS that will create such an effect.
Hi, That can be done with the custom code. Or you can find the appropriate plug-in for your CMS that will create such an effect. Sincerely, Hella
milu.cernochova
Can you write me the code? :)
Milu
Can you write me the code? :) Milu
No, we do not provide support for custom modifications.
Hi, No, we do not provide support for custom modifications. Sincerely, Hella
