CSS Issue
bsjelin
bsjelin posted this 16 January 2017
Hello - I had some issues with applying a plugin and this is what they were able to find as an issue with the css file of the template. Is this something that can be fixed?
Hello Brandon,
It seems there are some CSS parsing errors in the
/templates/timeless_v1/css/bootstrap.min.css?version=1.0.481 file. I
think it has something to do with the following code:
input[type=radio]{margin:4px 0 0;margin-top:1px\9;line-height:normal}
The part '1px\9' seems to be invalid and messing up the file when it
is minified and combined by the plugin. Excluding this file have
resolved this issue somewhat but I'd recommend fixing the error first
so the file can be included before using the Optimize CSS Delivery
feature. It sometimes doesn't work well when files are excluded.
I used http://csslint.net/ to help find the error.
Hello - I had some issues with applying a plugin and this is what they were able to find as an issue with the css file of the template. Is this something that can be fixed? > Hello Brandon, > > It seems there are some CSS parsing errors in the > /templates/timeless_v1/css/bootstrap.min.css?version=1.0.481 file. I > think it has something to do with the following code: > input[type=radio]{margin:4px 0 0;margin-top:1px\9;line-height:normal} > > The part '1px\9' seems to be invalid and messing up the file when it > is minified and combined by the plugin. Excluding this file have > resolved this issue somewhat but I'd recommend fixing the error first > so the file can be included before using the Optimize CSS Delivery > feature. It sometimes doesn't work well when files are excluded. > > I used http://csslint.net/ to help find the error.
12 Comments
Support Team posted this 18 January 2017
Themler uses Bootstrap framework and this line of code is provided by this framework. You can find it in bootstrap.min.css on http://getbootstrap.com/ too. This plugin will have problems with any bootstrap theme.
Hi, Themler uses Bootstrap framework and this line of code is provided by this framework. You can find it in bootstrap.min.css on http://getbootstrap.com/ too. This plugin will have problems with any bootstrap theme. Thank you, Olivia
bsjelin
bsjelin posted this 24 January 2017
Here is the next response from the developer.
The error in the file needs to be corrected. That's the only thing
that can work. Otherwise you will have to keep it excluded. View the
error that I pointed out to you: input[type=radio]{margin:4px 0
There ought to be a space between the 1px and the \9. This is a
parsing error and will cause issues based on how the css parser
processes errors. You may find more on that here:
https://www.w3.org/TR/css-syntax-3/#error-handling. This is especially
unforgiving when the CSS files are minified.
The theme on this website also uses bootstrap and considering the
popularity of bootstrap themes today if the problem was with bootstrap
that would be a major problem with this plugin. This is not the case.
I can only recall you with this problem.
Take a look at the original bootstrap file here:
https://maxcdn.bootstrapcdn.com/bootstrap/3.1.1/css/bootstrap.min.css.
Do a text search for \9 and you will see there's always a space
occurring before it. Perhaps the theme developer used a substandard
minification library to minify the CSS file, which has removed the
space. You will note that the original bootstrap file from maxcdn is
already minified but still retains the space.
If your theme has any CSS minification feature enabled try to disable
it and only allow JCH Optimize to handle the minification of your
files. Otherwise you can explore somehow using the original bootstrap
file in place of the one distributed with the theme if the developer
refuses to clean up his work.
Here is the next response from the developer. > The error in the file needs to be corrected. That's the only thing > that can work. Otherwise you will have to keep it excluded. View the > error that I pointed out to you: input[type=radio]{margin:4px 0 > 0;margin-top:1px\9;line-height:normal} > > There ought to be a space between the 1px and the \9. This is a > parsing error and will cause issues based on how the css parser > processes errors. You may find more on that here: > https://www.w3.org/TR/css-syntax-3/#error-handling. This is especially > unforgiving when the CSS files are minified. > > The theme on this website also uses bootstrap and considering the > popularity of bootstrap themes today if the problem was with bootstrap > that would be a major problem with this plugin. This is not the case. > I can only recall you with this problem. > > Take a look at the original bootstrap file here: > https://maxcdn.bootstrapcdn.com/bootstrap/3.1.1/css/bootstrap.min.css. > Do a text search for \9 and you will see there's always a space > occurring before it. Perhaps the theme developer used a substandard > minification library to minify the CSS file, which has removed the > space. You will note that the original bootstrap file from maxcdn is > already minified but still retains the space. > > If your theme has any CSS minification feature enabled try to disable > it and only allow JCH Optimize to handle the minification of your > files. Otherwise you can explore somehow using the original bootstrap > file in place of the one distributed with the theme if the developer > refuses to clean up his work.
rayem28362
rayem28362 posted this 11 November 2025
Solche CSS-Fehler können echt nerven – ich hatte mal ein ähnliches Problem mit einem Theme und brauchte ewig, um es zu beheben. Nach solchen technischen Pannen mache ich oft eine Pause und entspanne kurz bei royals tiger. Die Seite läuft stabil, bietet faire Spiele und gute Boni für Spieler aus Deutschland. Es hilft mir, den Kopf freizubekommen, bevor ich wieder ans Coden gehe.
Solche CSS-Fehler können echt nerven – ich hatte mal ein ähnliches Problem mit einem Theme und brauchte ewig, um es zu beheben. Nach solchen technischen Pannen mache ich oft eine Pause und entspanne kurz bei [royals tiger][1]. Die Seite läuft stabil, bietet faire Spiele und gute Boni für Spieler aus Deutschland. Es hilft mir, den Kopf freizubekommen, bevor ich wieder ans Coden gehe. [1]: https://royals-tiger.com.de
sdt49826
sdt49826 posted this 18 November 2025
This should be the best consolation to you that you are not wasting time as you do on using free courses or any other online exam preparation support such as exam collection and so on. Our International Certified Corporate Governance Officer Corporate Governance Officer content is time-tested, examined and approved by the best industry professionals. Hence our AGRC ICCGO products are immensely popular in the market.
Visit Now >>> https://www.exact2pass.com/ICCGO-pass.html
This should be the best consolation to you that you are not wasting time as you do on using free courses or any other online exam preparation support such as exam collection and so on. Our International Certified Corporate Governance Officer Corporate Governance Officer content is time-tested, examined and approved by the best industry professionals. Hence our AGRC ICCGO products are immensely popular in the market. Visit Now >>> [https://www.exact2pass.com/ICCGO-pass.html][1] [1]: https://www.exact2pass.com/ICCGO-pass.html
chinahousehold
chinahousehold posted this 21 November 2025
https://bothbest.postach.io/
https://bothbest.8b.io/
https://bothbest.hp.peraichi.com/
https://codimd.pirati.cz/s/0Ze3YjZph
https://www.elektormagazine.com/labs/252164/bothbest
https://www.imcas.com/en/profile/richard-perlot
https://paperpage.in/blogs/47402/Is-Bamboo-Better-Than-Laminate-Pros-Cons-Price-Breakdown
https://taggedface.com/blogs/52198/User-Reviews-of-Bamboo-Flooring-in-South-America-Which-Types
https://forum.motoshkola.od.ua/threads/user-reviews-of-bamboo-flooring-in-south-america-which-types-perform-best-and-why.84340/
https://bbs.superbuy.com/forum.php?mod=viewthread&tid=736206
https://social.contadordeinscritos.xyz/forums/thread/2011/Bamboo-Flooring-Price-Guide-2025-What-to-Expect-Per-Square
https://kadrmaskreations.com/forum/topic/top-marketing-strategies-for-dealers-selling-bamboo-flooring/
https://www.gooalsocial.com/blogs/view/15154
https://docs.stackshare.io/discuss/691fa8d7895444cf041b168d
https://docs.trybrass.com/discuss/691fa90e9eed259a57f6fcc4
https://parcheweb.com/forum/general/charlemos-de-nosotras/126828-warm-in-winter-cool-in-summer-bamboo-flooring%E2%80%99s-natural-advantage
https://velog.io/@bothbest/The-Best-Flooring-for-Families-Why-Bamboo-Is-the-1-Choice-d6c6gvzp
https://techdesigner.ru/posts/top-bamboo-flooring-importers-in-the-usa-whos-leading-the-market
https://mypaper.pchome.com.tw/bothbest/post/1382290713
https://drsridharias.com/forums/discussion/history/bamboo-vs-hardwood-flooring-which-is-better-for-your-budget-and-lifestyle
https://www.myfishingreport.com/blog-view.php?id=27645
https://international.projectwet.org/discussion/budget-vs-premium-bamboo-flooring-whats-difference-value
https://bothbest.bigcartel.com/product/carbonized-stand-woven-compressed-bamboo-flooring
https://sngine.fr/blogs/16085/Why-Strand-Woven-Bamboo-Flooring-Is-Worth-the-Price-Tag
https://tudomuaban.com/chi-tiet-rao-vat/2738771/budget-vs-premium-bamboo-flooring-whats-the-difference-in-value.html
https://blog.mycareindia.co.in/moso-bamboo-vs-other-species-whats-the-difference/
https://forumtransportu.pl/forum/temat/22227
https://bothbest.tokka-blog.com/
https://bothbest.tokka-blog.com/38941575/why-strand-woven-bamboo-flooring-is-worth-the-price-tag
https://bothbest.madmouseblog.com
https://bothbest.madmouseblog.com/19221951/budget-vs-premium-bamboo-flooring-what-s-the-difference-in-value
https://bothbest.livebloggs.com
https://bothbest.livebloggs.com/45203251/moso-bamboo-vs-other-species-what-s-the-difference
https://bothbest.bloggactivo.com
https://bothbest.bloggactivo.com/37657148/bamboo-vs-hardwood-flooring-which-is-better-for-your-budget-and-lifestyle
https://bothbest.postach.io/ https://bothbest.8b.io/ https://bothbest.hp.peraichi.com/ https://codimd.pirati.cz/s/0Ze3YjZph https://www.elektormagazine.com/labs/252164/bothbest https://www.imcas.com/en/profile/richard-perlot https://paperpage.in/blogs/47402/Is-Bamboo-Better-Than-Laminate-Pros-Cons-Price-Breakdown https://taggedface.com/blogs/52198/User-Reviews-of-Bamboo-Flooring-in-South-America-Which-Types https://forum.motoshkola.od.ua/threads/user-reviews-of-bamboo-flooring-in-south-america-which-types-perform-best-and-why.84340/ https://bbs.superbuy.com/forum.php?mod=viewthread&tid=736206 https://social.contadordeinscritos.xyz/forums/thread/2011/Bamboo-Flooring-Price-Guide-2025-What-to-Expect-Per-Square https://kadrmaskreations.com/forum/topic/top-marketing-strategies-for-dealers-selling-bamboo-flooring/ https://www.gooalsocial.com/blogs/view/15154 https://docs.stackshare.io/discuss/691fa8d7895444cf041b168d https://docs.trybrass.com/discuss/691fa90e9eed259a57f6fcc4 https://parcheweb.com/forum/general/charlemos-de-nosotras/126828-warm-in-winter-cool-in-summer-bamboo-flooring%E2%80%99s-natural-advantage https://velog.io/@bothbest/The-Best-Flooring-for-Families-Why-Bamboo-Is-the-1-Choice-d6c6gvzp https://techdesigner.ru/posts/top-bamboo-flooring-importers-in-the-usa-whos-leading-the-market https://mypaper.pchome.com.tw/bothbest/post/1382290713 https://drsridharias.com/forums/discussion/history/bamboo-vs-hardwood-flooring-which-is-better-for-your-budget-and-lifestyle https://www.myfishingreport.com/blog-view.php?id=27645 https://international.projectwet.org/discussion/budget-vs-premium-bamboo-flooring-whats-difference-value https://bothbest.bigcartel.com/product/carbonized-stand-woven-compressed-bamboo-flooring https://sngine.fr/blogs/16085/Why-Strand-Woven-Bamboo-Flooring-Is-Worth-the-Price-Tag https://tudomuaban.com/chi-tiet-rao-vat/2738771/budget-vs-premium-bamboo-flooring-whats-the-difference-in-value.html https://blog.mycareindia.co.in/moso-bamboo-vs-other-species-whats-the-difference/ https://forumtransportu.pl/forum/temat/22227 https://bothbest.tokka-blog.com/ https://bothbest.tokka-blog.com/38941575/why-strand-woven-bamboo-flooring-is-worth-the-price-tag https://bothbest.madmouseblog.com https://bothbest.madmouseblog.com/19221951/budget-vs-premium-bamboo-flooring-what-s-the-difference-in-value https://bothbest.livebloggs.com https://bothbest.livebloggs.com/45203251/moso-bamboo-vs-other-species-what-s-the-difference https://bothbest.bloggactivo.com https://bothbest.bloggactivo.com/37657148/bamboo-vs-hardwood-flooring-which-is-better-for-your-budget-and-lifestyle
Abbas Khan
Abbas Khan posted this 12 January 2026
Quando o assunto é baixar Baixar Cinema APK v3.2.0 atualizado, é importante compreender que versões mais recentes costumam oferecer vantagens claras em comparação com versões antigas, pois trazem correções de bugs, ajustes na interface, otimizações de velocidade e, muitas vezes, melhorias no sistema de busca e organização do catálogo, o que torna a navegação mais rápida e eficiente, além disso atualizações frequentes ajudam a manter o aplicativo funcional diante das mudanças do sistema Android.
Quando o assunto é baixar **[Baixar Cinema APK v3.2.0][1]** atualizado, é importante compreender que versões mais recentes costumam oferecer vantagens claras em comparação com versões antigas, pois trazem correções de bugs, ajustes na interface, otimizações de velocidade e, muitas vezes, melhorias no sistema de busca e organização do catálogo, o que torna a navegação mais rápida e eficiente, além disso atualizações frequentes ajudam a manter o aplicativo funcional diante das mudanças do sistema Android. [1]: https://cinemaapkapp.com.br/cinema-apk-v3-2-0/
sarahjones91920
sarahjones91920 posted this 26 January 2026
Every leap praises bold timing as spins slice through layered air paths wacky flip.
Every leap praises bold timing as spins slice through layered air paths [wacky flip][1]. [1]: https://wacky-flip.io
desirable.gayal.bzka
desirable.gayal.bzka posted this 02 February 2026
This type of issue is generally fixable, Pokepath TD either by adjusting the template’s CSS, adding custom overrides, or modifying how the plugin’s styles are loaded, though it may require technical CSS knowledge or support from a developer.
This type of issue is generally fixable, [Pokepath TD](https://pokepathtd.io) either by adjusting the template’s CSS, adding custom overrides, or modifying how the plugin’s styles are loaded, though it may require technical CSS knowledge or support from a developer.
sanskarisumann
sanskarisumann posted this 03 March 2026
Selecting Escort Delhi introduces a soft and reassuring presence into your free hours. Their friendly tone and composed personality help create a setting where conversation flows without effort. The experience feels steady and unhurried, offering a peaceful break from everyday demands.
Escorts Service in Golf Links
Govindpuri Escorts
Escorts in Green Park
Gulmohar Park Escorts Service
Escorts Service Hauz Khas Enclave
Selecting Escort Delhi introduces a soft and reassuring presence into your free hours. Their friendly tone and composed personality help create a setting where conversation flows without effort. The experience feels steady and unhurried, offering a peaceful break from everyday demands. [Escorts Service in Golf Links][1] [Govindpuri Escorts][2] [Escorts in Green Park][3] [Gulmohar Park Escorts Service][4] [Escorts Service Hauz Khas Enclave][5] [1]: https://golf-links.rashmibhargav.com/ [2]: https://govindpuri.rashmibhargav.com/ [3]: https://green-park.rashmibhargav.com/ [4]: https://gulmohar-park.rashmibhargav.com/ [5]: https://hauz-khas-enclave.rashmibhargav.com/
chinahousehold
chinahousehold posted this 20 March 2026
http://alphaenc.kr/bbs/board.php?bo_table=alpha_qna&wr_id=52709
https://bothbest.micro.blog/about/
https://www.tunwalai.com/Profile/16221272
https://pinkary.com/@bothbest
https://git.student.rea.ru/bothbest
https://pyweek.org/u/bothbest/
https://www.protenders.com/companies/bothbest
https://doras.to/bothbest
https://doras.to/bothbest/post/click-lock-bamboo-floors-are-they-really-waterproof
http://www.effecthub.com/item/468626
https://www.oureducation.in/answers/profile/bothbest/
https://videos.fortiddns.com/@bothbest?page=about
https://www.cosmosfarm.com/user/profile/38108
https://4irdeveloper.com/index.php/forums/view_forumtopic_details/50168
http://dtan.thaiembassy.de/uncategorized/2562/?mingleforumaction=profile&id=477263
https://doks.komun.org/s/2bJyIAsnd
https://collectednotes.com/bothbest/the-eco-benefits-of-choosing-compressed-bamboo-floors/
https://torre.ai/teams/Bothbest?r=7hIVcj9a
https://chillspot1.com/user/hssolar
https://ayema.ng/bothbest
https://ayema.ng/blogs/351247/Woven-Bamboo-Flooring-Maintenance-Simple-Tips-for-Long-Life
https://www.adsthumb.com/us/profile/bothbest
https://www.adsthumb.com/why-homeowners-prefer-strand-woven-bamboo-over-laminate-lNbWBpxJayg
https://bingebooks.com/profile/bothbest
https://bsky.app/profile/bothbest.bsky.social
https://bsky.app/profile/bothbest.bsky.social/post/3mhfh2jvulc2b
https://www.24liveblog.com/user/4020516878468333802
https://www.24liveblog.com/live/4020520876579793058
https://www.24liveblog.com/live/4069064955684724030
https://chinasolar.blog.shinobi.jp/solar/10-reasons-compressed-bamboo
https://hssolar.blog.shinobi.jp/bamboo/how-to-create-a-calm-nature
https://bathtub.blog.shinobi.jp
https://bathtub.blog.shinobi.jp/spa/how-to-get-high-quality-bamboo
https://beatsaver.com/playlists/1160345
https://o4ezhzklmi55thxs.umso.co/blog/how-chinese-bamboo-fiber-bedding-helps-improve-sleep-quality
https://bambooflooring.game-ss.com/bamboo/how-chinese-bamboo-fiber-bedding
https://bothbest.hotglue.me/?China-Bamboo-Tableware-Sets
https://hssolar.blog.shinobi.jp/bamboo/china-bamboo-tableware-sets
https://chinasolar.blog.shinobi.jp/solar/what-makes-chinese-bamboo
https://www.sooplive.co.kr/station/bothbest/post/190241875
https://www.2biz.ro/china-bamboo-lampshades-pf
https://bothbest.systeme.io/bamboo/china-bamboo-outdoor-furniture-performance-under-sun-and-rain
http://alphaenc.kr/bbs/board.php?bo_table=alpha_qna&wr_id=52709 https://bothbest.micro.blog/about/ https://www.tunwalai.com/Profile/16221272 https://pinkary.com/@bothbest https://git.student.rea.ru/bothbest https://pyweek.org/u/bothbest/ https://www.protenders.com/companies/bothbest https://doras.to/bothbest https://doras.to/bothbest/post/click-lock-bamboo-floors-are-they-really-waterproof http://www.effecthub.com/item/468626 https://www.oureducation.in/answers/profile/bothbest/ https://videos.fortiddns.com/@bothbest?page=about https://www.cosmosfarm.com/user/profile/38108 https://4irdeveloper.com/index.php/forums/view_forumtopic_details/50168 http://dtan.thaiembassy.de/uncategorized/2562/?mingleforumaction=profile&id=477263 https://doks.komun.org/s/2bJyIAsnd https://collectednotes.com/bothbest/the-eco-benefits-of-choosing-compressed-bamboo-floors/ https://torre.ai/teams/Bothbest?r=7hIVcj9a https://chillspot1.com/user/hssolar https://ayema.ng/bothbest https://ayema.ng/blogs/351247/Woven-Bamboo-Flooring-Maintenance-Simple-Tips-for-Long-Life https://www.adsthumb.com/us/profile/bothbest https://www.adsthumb.com/why-homeowners-prefer-strand-woven-bamboo-over-laminate-lNbWBpxJayg https://bingebooks.com/profile/bothbest https://bsky.app/profile/bothbest.bsky.social https://bsky.app/profile/bothbest.bsky.social/post/3mhfh2jvulc2b https://www.24liveblog.com/user/4020516878468333802 https://www.24liveblog.com/live/4020520876579793058 https://www.24liveblog.com/live/4069064955684724030 https://chinasolar.blog.shinobi.jp/solar/10-reasons-compressed-bamboo https://hssolar.blog.shinobi.jp/bamboo/how-to-create-a-calm-nature https://bathtub.blog.shinobi.jp https://bathtub.blog.shinobi.jp/spa/how-to-get-high-quality-bamboo https://beatsaver.com/playlists/1160345 https://o4ezhzklmi55thxs.umso.co/blog/how-chinese-bamboo-fiber-bedding-helps-improve-sleep-quality https://bambooflooring.game-ss.com/bamboo/how-chinese-bamboo-fiber-bedding https://bothbest.hotglue.me/?China-Bamboo-Tableware-Sets https://hssolar.blog.shinobi.jp/bamboo/china-bamboo-tableware-sets https://chinasolar.blog.shinobi.jp/solar/what-makes-chinese-bamboo https://www.sooplive.co.kr/station/bothbest/post/190241875 https://www.2biz.ro/china-bamboo-lampshades-pf https://bothbest.systeme.io/bamboo/china-bamboo-outdoor-furniture-performance-under-sun-and-rain
xevpass
xevpass posted this 11 April 2026
It looks like you've encountered a common CSS issue that can cause problems with plugins. Fixing the invalid code should help resolve the parsing errors and improve your site's performance. Once you sort that out, consider checking out Frog vs Mural Girl 3 for some fun and engaging content that can enhance your website experience!
It looks like you've encountered a common CSS issue that can cause problems with plugins. Fixing the invalid code should help resolve the parsing errors and improve your site's performance. Once you sort that out, consider checking out [Frog vs Mural Girl 3][1] for some fun and engaging content that can enhance your website experience! [1]: https://www.frogvsmuralgirl.org/
nowwatchonlinetv
nowwatchonlinetv posted this 17 April 2026
Voidstrap is a third-party Roblox launcher that improves performance and customization, with Voidstrap download offering more control than the official client.
Voidstrap is a third-party Roblox launcher that improves performance and customization, with [Voidstrap download][1] offering more control than the official client. [1]: https://voidstrap.net/
