licence renewal
maryann65
maryann65 posted this 17 January 2017
what happens when you forget to renew your license? Can you do it after is due? Can you continue using the same template you did it before?
what happens when you forget to renew your license? Can you do it after is due? Can you continue using the same template you did it before? Thanks
Support Team posted this 18 January 2017
Hi Mariana,
Nothing bad will happen if you forget to renew your license :)
You can simply do it later and the price will stay the same.
You can continue working on your theme but you won't be able to apply the latest updates though.
Ivan
Hi Mariana, Nothing bad will happen if you forget to renew your license :) You can simply do it later and the price will stay the same. You can continue working on your theme but you won't be able to apply the latest updates though. Please let us know if you have any further questions. Thanks, Ivan
maryann65
maryann65 posted this 18 January 2017
To renew it I have to login in the account and what are the other steps? Can you provide me the steps. And I assume that I can pay it with discover? The latest updates can modify the template is already in use?
To renew it I have to login in the account and what are the other steps? Can you provide me the steps. And I assume that I can pay it with discover? The latest updates can modify the template is already in use? Thanks
Support Team posted this 19 January 2017
To renew the license you need to log in with the account that was used to purchase the license before. Then open the http://themler.com/Purchase page, the old license will be listed on the top. Press the Upgrade button near it and you will see the prices with the discount in the table below.
You mean that you have created templates in Themler before and you need to edit them further with the new updated version? Yes, that is possible if your themes were saved with the editor included.
Hi, To renew the license you need to log in with the account that was used to purchase the license before. Then open the http://themler.com/Purchase page, the old license will be listed on the top. Press the Upgrade button near it and you will see the prices with the discount in the table below. >The latest updates can modify the template is already in use? You mean that you have created templates in Themler before and you need to edit them further with the new updated version? Yes, that is possible if your themes were saved with the editor included. Sincerely, Hella
