themler for HTMl with SSL
forreggbor
forreggbor posted this 22 January 2017
Upload blank themler html to my development website and open it with HTTPS doesn't work in latest Chrome. It blocks loading because of themler would like to open sources from non-secure website. After check the blocked content I found two pngs from billiondigital website. See attached pictures.
Would be good to provide remote resources via HTTPS by detecting the server's settings hosting the website.
Upload blank themler html to my development website and open it with HTTPS doesn't work in latest Chrome. It blocks loading because of themler would like to open sources from non-secure website. After check the blocked content I found two pngs from billiondigital website. See attached pictures. Would be good to provide remote resources via HTTPS by detecting the server's settings hosting the website.
10 Comments
jim105
jim105 posted this 22 January 2017
I see the same problem. All of the font references are requesting google fonts over http -
If you open the page in a code editor or notepad, you will find a line in the code that looks like this -
href='http://fonts.googleapis.com/css?...
Change 'http://' to 'https://'and save, upload and reload your page.
The Themler team should fix this so that it loads everything from the current protocol href='//fonts.googleapis.com/...'
I see the same problem. All of the font references are requesting google fonts over http - If you open the page in a code editor or notepad, you will find a line in the code that looks like this - href='http://fonts.googleapis.com/css?... Change 'http://' to 'https://'and save, upload and reload your page. The Themler team should fix this so that it loads everything from the current protocol href='//fonts.googleapis.com/...'
Support Team posted this 25 January 2017
Hello forreggbor ,
please create a new private topic where provide link to the live page which demonstrates the issue and access credentials to Themler theme.
Hello forreggbor , please create a new private topic where provide link to the live page which demonstrates the issue and access credentials to Themler theme. regards, Aileen
Hello Jim,
try include directive without protocol
href='//fonts.googleapis.com/css?family....'
Hello Jim, try include directive without protocol href='//fonts.googleapis.com/css?family....' Regards, Aileen
forreggbor
forreggbor posted this 25 January 2017
Hello forreggbor ,
Doesn't need to do because it happens every time. Just create a new virtualhost, install SSL (Letsencrypt for example), enable ssl/https and open themler from this new host forced to use https protocol. You'll see.
> Hello forreggbor , > please create a new private topic where provide link to the live page which demonstrates the issue and access credentials to Themler theme. > > regards, > Aileen Doesn't need to do because it happens every time. Just create a new virtualhost, install SSL (Letsencrypt for example), enable ssl/https and open themler from this new host forced to use https protocol. You'll see.
forreggbor
Hello Jim,
If you open without protocol then it works.
The problem is that the protocol is hardcoded into the default themler theme. It's really petty that I have to edit the generated code by hand before I publish the website. That's why I use Themler to avoid code editing.
> Hello Jim, > try include directive without protocol > > href='//fonts.googleapis.com/css?family....' > > Regards, > Aileen If you open without protocol then it works. The problem is that the protocol is hardcoded into the default themler theme. It's really petty that I have to edit the generated code by hand before I publish the website. That's why I use Themler to avoid code editing.
Support Team posted this 26 January 2017
we're aware of this issue and this is in our wish list.
Right now please edit the file after exporting the theme.
Hello, we're aware of this issue and this is in our wish list. Right now please edit the file after exporting the theme. Regards, Aileen
markus.schubert
markus.schubert posted this 22 August 2018
are there any news regarding this topic?
Kind Regards,
Markus
Hello, are there any news regarding this topic? Kind Regards, Markus
Support Team posted this 04 September 2018
The issue was fixed on our end. Please try using the latest version.
Hi, The issue was fixed on our end. Please try using the latest version. Sincerely, Hella
markus.schubert
markus.schubert posted this 18 September 2018
With the newest themler Version (manifest 456) we still get this error-massage from the console when loading themler editor via https:
Synchrone XMLHttpRequests am Haupt-Thread sollte nicht mehr verwendet werden, weil es nachteilige Effekte für das Erlebnis der Endbenutzer hat. Für weitere Hilfe siehe http://xhr.spec.whatwg.org/ project.js:116:12
XML-Verarbeitungsfehler: Syntax-Fehler
Adresse: https://cabsgmbh.de/manifest/456.manifest
Zeile Nr. 1, Spalte 1: 456.manifest:1:1
Laden von gemischten aktiven Inhalten "http://cstatic.themler.io/themler/455/start.js" wurde blockiert.[Weitere Informationen] loader.js:7:8
**Laden fehlgeschlagen für das
With the newest themler Version (manifest 456) we still get this error-massage from the console when loading themler editor via https: Synchrone XMLHttpRequests am Haupt-Thread sollte nicht mehr verwendet werden, weil es nachteilige Effekte für das Erlebnis der Endbenutzer hat. Für weitere Hilfe siehe http://xhr.spec.whatwg.org/ project.js:116:12 XML-Verarbeitungsfehler: Syntax-Fehler Adresse: https://cabsgmbh.de/manifest/456.manifest Zeile Nr. 1, Spalte 1: 456.manifest:1:1 Laden von gemischten aktiven Inhalten "**http://cstatic.themler.io/themler/455/start.js" wurde blockiert.[Weitere Informationen] loader.js:7:8** **Laden fehlgeschlagen für das
Web IT Solutions LLP
Web IT Solutions LLP posted this 12 April 2020
Great blog post more perfect as per the SEO and to get more visibility and ranking in Google. We too work keep it up like in the blogs http://webnoesys.com and https://anandguru.live and we have to follow it, thank you.
