Bug with top navigation wordpress
Malinka
Malinka posted this 23 January 2017
When i use 2 columns in header and put top navigation in one of the columns all looks good but as soon as i make changes in Themler my primary menu is disabled and i need to enable again in wordpress menu settings.
I have attached top section with 2 columns if someone wants to replicate this bug.
Best regards
Malinka
Hi When i use 2 columns in header and put top navigation in one of the columns all looks good but as soon as i make changes in Themler my primary menu is disabled and i need to enable again in wordpress menu settings. I have attached top section with 2 columns if someone wants to replicate this bug. Best regards Malinka
Support Team posted this 23 January 2017
The issue is not related to section itself. It happens in the moment when you start Themler.
This issue will be fixed in the next Themler update.
Hi, The issue is not related to section itself. It happens in the moment when you start Themler. This issue will be fixed in the next Themler update. Thank you, Olivia
