Inserting PHP
cogray
cogray posted this 23 January 2017
I'd like to add this code to Joomla position for footer
© <?php $startyear $curyear echo $startyear . (($startyear ! '-' . $curyear : '');?> www.example.com
but when I save Themler rems out the PHP portion to look like this...
<!--?php
$startYear = 2010;
$curYear = date('Y');
echo $startYear . (($startYear != $curYear) ? '-' . $curYear : '');
www.example.com
Is there anyway to add a dynamic copyright date to a Joomla template within the themler tenmplate?
I'd like to add this code to Joomla position for footer &copy; &lt;?php $startyear $curyear echo $startyear . (($startyear ! &#39;-&#39; . $curyear : &#39;&#39;);?&gt; www.example.com but when I save Themler rems out the PHP portion to look like this... &lt;!--?php $startYear = 2010; $curYear = date(&#39;Y&#39;); echo $startYear . (($startYear != $curYear) ? &#39;-&#39; . $curYear : &#39;&#39;); ?--&gt; www.example.com Is there anyway to add a dynamic copyright date to a Joomla template within the themler tenmplate?
8 Comments
Support Team posted this 23 January 2017
Please use the CMS Code control that can be found under the Insert >> More tab. Make sure that you insert the code within the HTML Source tab.
Hi, Please use the CMS Code control that can be found under the Insert >> More tab. Make sure that you insert the code within the HTML Source tab. Sincerely, Hella
cogray
cogray posted this 25 January 2017
Sorry but I don't understand. I can see a CMS control and a HTML control but I don't know what you mean when you say "Make sure that you insert the code within the HTML Source tab."
Are you saying that there is an HTML "TAB" within the CMS control?
Sorry but I don't understand. I can see a CMS control and a HTML control but I don't know what you mean when you say "Make sure that you insert the code within the HTML Source tab." Are you saying that there is an HTML "TAB" within the CMS control?
Bayern
Bayern posted this 25 January 2017
i don't need to do this in Themler
I use the JCE Editor and put the code in the source code of the Modul
i don't need to do this in Themler I use the JCE Editor and put the code in the source code of the Modul
Support Team posted this 26 January 2017
If you need to add php code to the theme in Themler you should use CMS Code control (Insert tab >> More).
The code
<?php $startYear = 2010; $curYear = date('Y'); echo $startYear . (($startYear != $curYear) ? '-' . $curYear : '');?>
works just fine on my side.
Hi, If you need to add php code to the theme in Themler you should use CMS Code control (Insert tab >> More). The code `<?php $startYear = 2010; $curYear = date('Y'); echo $startYear . (($startYear != $curYear) ? '-' . $curYear : '');?>` works just fine on my side. Thank you, Olivia
tomy3
tomy3 posted this 07 October 2017
Hello, I dont have this CSM code control!!! where it is???.
Thanks.
Hello, I dont have this CSM code control!!! where it is???. Thanks.
Support Team posted this 09 October 2017
It's under the Insert >> More tab.
Hi, It's under the Insert >> More tab. Sincerely, Hella
studwork1742
studwork1742 posted this 19 November 2025
In letzter Zeit war ich oft unentschlossen, was ich mit meinem Wochenende machen soll. Ich wollte etwas Aufregendes online. Dann fand ich spino gambino casino, mit Live-Dealer-Spielen, Slots und interaktiven Turnieren. Auf spino-gambino sind deutsche Spieler bei saisonalen Events dabei, es gibt Reload-Boni und Wochenend-Promos. Es gefällt mir, weil es das Wochenende richtig belebt und spannend macht.
In letzter Zeit war ich oft unentschlossen, was ich mit meinem Wochenende machen soll. Ich wollte etwas Aufregendes online. Dann fand ich [spino gambino casino][1], mit Live-Dealer-Spielen, Slots und interaktiven Turnieren. Auf spino-gambino sind deutsche Spieler bei saisonalen Events dabei, es gibt Reload-Boni und Wochenend-Promos. Es gefällt mir, weil es das Wochenende richtig belebt und spannend macht. [1]: https://spino-gambino.com.de
chinahousehold
chinahousehold posted this 21 November 2025
https://bothbest.postach.io/
https://bothbest.8b.io/
https://bothbest.hp.peraichi.com/
https://codimd.pirati.cz/s/0Ze3YjZph
https://www.elektormagazine.com/labs/252164/bothbest
https://www.imcas.com/en/profile/richard-perlot
https://paperpage.in/blogs/47402/Is-Bamboo-Better-Than-Laminate-Pros-Cons-Price-Breakdown
https://taggedface.com/blogs/52198/User-Reviews-of-Bamboo-Flooring-in-South-America-Which-Types
https://forum.motoshkola.od.ua/threads/user-reviews-of-bamboo-flooring-in-south-america-which-types-perform-best-and-why.84340/
https://bbs.superbuy.com/forum.php?mod=viewthread&tid=736206
https://social.contadordeinscritos.xyz/forums/thread/2011/Bamboo-Flooring-Price-Guide-2025-What-to-Expect-Per-Square
https://kadrmaskreations.com/forum/topic/top-marketing-strategies-for-dealers-selling-bamboo-flooring/
https://www.gooalsocial.com/blogs/view/15154
https://docs.stackshare.io/discuss/691fa8d7895444cf041b168d
https://docs.trybrass.com/discuss/691fa90e9eed259a57f6fcc4
https://parcheweb.com/forum/general/charlemos-de-nosotras/126828-warm-in-winter-cool-in-summer-bamboo-flooring%E2%80%99s-natural-advantage
https://velog.io/@bothbest/The-Best-Flooring-for-Families-Why-Bamboo-Is-the-1-Choice-d6c6gvzp
https://techdesigner.ru/posts/top-bamboo-flooring-importers-in-the-usa-whos-leading-the-market
https://mypaper.pchome.com.tw/bothbest/post/1382290713
https://drsridharias.com/forums/discussion/history/bamboo-vs-hardwood-flooring-which-is-better-for-your-budget-and-lifestyle
https://www.myfishingreport.com/blog-view.php?id=27645
https://international.projectwet.org/discussion/budget-vs-premium-bamboo-flooring-whats-difference-value
https://bothbest.bigcartel.com/product/carbonized-stand-woven-compressed-bamboo-flooring
https://sngine.fr/blogs/16085/Why-Strand-Woven-Bamboo-Flooring-Is-Worth-the-Price-Tag
https://tudomuaban.com/chi-tiet-rao-vat/2738771/budget-vs-premium-bamboo-flooring-whats-the-difference-in-value.html
https://blog.mycareindia.co.in/moso-bamboo-vs-other-species-whats-the-difference/
https://forumtransportu.pl/forum/temat/22227
https://bothbest.tokka-blog.com/
https://bothbest.tokka-blog.com/38941575/why-strand-woven-bamboo-flooring-is-worth-the-price-tag
https://bothbest.madmouseblog.com
https://bothbest.madmouseblog.com/19221951/budget-vs-premium-bamboo-flooring-what-s-the-difference-in-value
https://bothbest.livebloggs.com
https://bothbest.livebloggs.com/45203251/moso-bamboo-vs-other-species-what-s-the-difference
https://bothbest.bloggactivo.com
https://bothbest.bloggactivo.com/37657148/bamboo-vs-hardwood-flooring-which-is-better-for-your-budget-and-lifestyle
https://bothbest.postach.io/ https://bothbest.8b.io/ https://bothbest.hp.peraichi.com/ https://codimd.pirati.cz/s/0Ze3YjZph https://www.elektormagazine.com/labs/252164/bothbest https://www.imcas.com/en/profile/richard-perlot https://paperpage.in/blogs/47402/Is-Bamboo-Better-Than-Laminate-Pros-Cons-Price-Breakdown https://taggedface.com/blogs/52198/User-Reviews-of-Bamboo-Flooring-in-South-America-Which-Types https://forum.motoshkola.od.ua/threads/user-reviews-of-bamboo-flooring-in-south-america-which-types-perform-best-and-why.84340/ https://bbs.superbuy.com/forum.php?mod=viewthread&tid=736206 https://social.contadordeinscritos.xyz/forums/thread/2011/Bamboo-Flooring-Price-Guide-2025-What-to-Expect-Per-Square https://kadrmaskreations.com/forum/topic/top-marketing-strategies-for-dealers-selling-bamboo-flooring/ https://www.gooalsocial.com/blogs/view/15154 https://docs.stackshare.io/discuss/691fa8d7895444cf041b168d https://docs.trybrass.com/discuss/691fa90e9eed259a57f6fcc4 https://parcheweb.com/forum/general/charlemos-de-nosotras/126828-warm-in-winter-cool-in-summer-bamboo-flooring%E2%80%99s-natural-advantage https://velog.io/@bothbest/The-Best-Flooring-for-Families-Why-Bamboo-Is-the-1-Choice-d6c6gvzp https://techdesigner.ru/posts/top-bamboo-flooring-importers-in-the-usa-whos-leading-the-market https://mypaper.pchome.com.tw/bothbest/post/1382290713 https://drsridharias.com/forums/discussion/history/bamboo-vs-hardwood-flooring-which-is-better-for-your-budget-and-lifestyle https://www.myfishingreport.com/blog-view.php?id=27645 https://international.projectwet.org/discussion/budget-vs-premium-bamboo-flooring-whats-difference-value https://bothbest.bigcartel.com/product/carbonized-stand-woven-compressed-bamboo-flooring https://sngine.fr/blogs/16085/Why-Strand-Woven-Bamboo-Flooring-Is-Worth-the-Price-Tag https://tudomuaban.com/chi-tiet-rao-vat/2738771/budget-vs-premium-bamboo-flooring-whats-the-difference-in-value.html https://blog.mycareindia.co.in/moso-bamboo-vs-other-species-whats-the-difference/ https://forumtransportu.pl/forum/temat/22227 https://bothbest.tokka-blog.com/ https://bothbest.tokka-blog.com/38941575/why-strand-woven-bamboo-flooring-is-worth-the-price-tag https://bothbest.madmouseblog.com https://bothbest.madmouseblog.com/19221951/budget-vs-premium-bamboo-flooring-what-s-the-difference-in-value https://bothbest.livebloggs.com https://bothbest.livebloggs.com/45203251/moso-bamboo-vs-other-species-what-s-the-difference https://bothbest.bloggactivo.com https://bothbest.bloggactivo.com/37657148/bamboo-vs-hardwood-flooring-which-is-better-for-your-budget-and-lifestyle
