Can't open my WP theme, get an alert
mail277
mail277 posted this 24 January 2017
I tried to import/open an older artx theme today. Now I can't open my WP themes anymore. After logging in to WP, I get an alert and then the Themler homepage opens.
Alert screenshot attached.
What can I do?
Thank you!
Sabine
Hi, I tried to import/open an older artx theme today. Now I can't open my WP themes anymore. After logging in to WP, I get an alert and then the Themler homepage opens. Alert screenshot attached. What can I do? Thank you! Sabine
Support Team posted this 24 January 2017
Hello Sabine,
1. Backup all theme folders somewhere on your computer. The path is shown in the Theme Management screen after selecting some CMS, for example, C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress.
6. Download latest version of Themler for Windows from themler.com, install it and try to start with Themler for Wordpress and create a theme.
As for the .artx project - please try this latest update, it is possible to export themes for Themler for Joomla, Wordpress and HTML with this version:
Hello Sabine, Please follow the steps below: 1. Backup all theme folders somewhere on your computer. The path is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress`. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Download latest version of Themler for Windows from themler.com, install it and try to start with Themler for Wordpress and create a theme. Please let us know the result. As for the .artx project - please try this latest update, it is possible to export themes for Themler for Joomla, Wordpress and HTML with this version: www.artisteer.com/media/p4/files/Artisteer.4.3.0.60928.exe Sincerely, Nettie, BillionDigital Team
mail277
Hi Nettie,
I am using Mac OS, same procedure?
Thanks!
Sabine
Hi Nettie, I am using Mac OS, same procedure? Thanks! Sabine
Support Team posted this 25 January 2017
The procedure is similar:
1. Backup the themes - they can be accessed in this way: Go >> Go to Folder >> type ~/Library and ENTER >> Themler >> hd_data >> cms >> choose CMS.
2. Completely uninstall Themler.
3. Reboot the computer, then download Themler for Mac the latest version from our website, install it and start a new theme for Themler for Wordpress.
Hello, The procedure is similar: 1. Backup the themes - they can be accessed in this way: Go >> Go to Folder >> type `~/Library` and ENTER >> Themler >> hd_data >> cms >> choose CMS. 2. Completely uninstall Themler. 3. Reboot the computer, then download Themler for Mac the latest version from our website, install it and start a new theme for Themler for Wordpress. Sincerely, Nettie, BillionDigital Team
alexarafatonline
alexarafatonline posted this 29 October 2025
Hi Sabine, it sounds like the older Artx theme might be conflicting with your current Themler setup. Try deactivating the theme via FTP or your hosting panel, then reactivate a default WP theme to regain access. I had a similar issue while customizing slot gacor layouts on Ligaciputra — sometimes outdated files just don’t sync well with newer systems.
Hi Sabine, it sounds like the older Artx theme might be conflicting with your current Themler setup. Try deactivating the theme via FTP or your hosting panel, then reactivate a default WP theme to regain access. I had a similar issue while customizing [slot gacor][1] layouts on Ligaciputra — sometimes outdated files just don’t sync well with newer systems. [1]: https://www.ecofabulous.com/modernliving/
alexarafatonline
alexarafatonline posted this 27 November 2025
Hi Sabine,
It sounds like you're experiencing an issue with the Themler theme and WordPress integration. Try the following:
Disable Themler Plugin: Via FTP or cPanel, navigate to wp-content/plugins/ and rename the themler folder to deactivate it. This should allow you to log in and access your themes.
Clear Browser Cache: Sometimes a cache issue can cause redirection problems, so clearing it might help.
Update Themes/Plugins: Ensure your themes and plugins are up to date to avoid compatibility issues.
In the ever-growing world of online gaming, just like with Konohatoto, where players need a reliable and accessible platform, WordPress themes require a smooth, secure setup to ensure everything works without glitches.
Good luck!
Hi Sabine, It sounds like you're experiencing an issue with the Themler theme and WordPress integration. Try the following: Disable Themler Plugin: Via FTP or cPanel, navigate to wp-content/plugins/ and rename the themler folder to deactivate it. This should allow you to log in and access your themes. Clear Browser Cache: Sometimes a cache issue can cause redirection problems, so clearing it might help. Update Themes/Plugins: Ensure your themes and plugins are up to date to avoid compatibility issues. In the ever-growing world of online gaming, just like with [Konohatoto][1], where players need a reliable and accessible platform, WordPress themes require a smooth, secure setup to ensure everything works without glitches. Good luck! [1]: https://highheelstohotwheels.com/2013/03/easter-crafts-cocktails/
