Offsite Menu Link
ImageByDesign
ImageByDesign posted this 24 January 2017
How in the world do I add an offsite link to the menu?? I see no option for that at all! I'm surprised you do not offer that option in the menu section.
12 Comments
ImageByDesign
Ok for all who would like to know the answer to this I figured it out:
1) create a New Page
2) Select the Properties value from the Pages dropdown on the left side bar
3) In the Properties section which will pop up to the right side of your screen
a) change the Title to the name you want in the menu
b) repeat with Head Title
c) repeat with Navigation Label
d) Look down below the Show in Horizontal Menu and Show in Vertical Menu options and add the HTML to the Custom URL and I recommend you select Target to Blank
This should then add an offsite link to another website that will pop-up a in a new window.
Note: Support - please add this to the HTML portion of your documentation so someone can readily find this. Thank you!
Ok for all who would like to know the answer to this I figured it out: 1) create a New Page 2) Select the Properties value from the Pages dropdown on the left side bar 3) In the Properties section which will pop up to the right side of your screen a) change the Title to the name you want in the menu b) repeat with Head Title c) repeat with Navigation Label d) Look down below the Show in Horizontal Menu and Show in Vertical Menu options and add the HTML to the Custom URL and I recommend you select Target to Blank This should then add an offsite link to another website that will pop-up a in a new window. Note: Support - please add this to the HTML portion of your documentation so someone can readily find this. Thank you!
Support Team posted this 25 January 2017
Nice to hear that you have found the solution. We'll consider adding this to the documentation. Also anyone will be able to find this thread on the forums to see the solution.
Hi, Nice to hear that you have found the solution. We'll consider adding this to the documentation. Also anyone will be able to find this thread on the forums to see the solution. Sincerely, Hella
ellysehix
ellysehix posted this 24 April 2025
Need expert Economics Assignment Help or struggling with Database Assignment Help? Get professional guidance from qualified tutors—accurate solutions, timely delivery, and full support to boost your grades and confidence!
Need expert [Economics Assignment Help][1] or struggling with [Database Assignment Help][2]? Get professional guidance from qualified tutors—accurate solutions, timely delivery, and full support to boost your grades and confidence! [1]: https://au1.globalassignmenthelp.com.au/economics-assignment-help [2]: https://au1.globalassignmenthelp.com.au/database-assignment-help
voowkuv
voowkuv posted this 25 April 2025
Hi all! Found Casino Niagara while checking out Canadian online casinos and I’m glad I clicked. The slots are what got me to stay — loads of them, from simple 3-reel setups to those crazy 243-ways-to-win ones. I’ve already made the Starburst free spins part of my nightly routine. Plus, there are live dealer games that work well even on slow Wi-Fi, which is a miracle in some parts of Canada. I’ll be sticking with this one for a while.
Hi all! Found [Casino Niagara][1] while checking out Canadian online casinos and I’m glad I clicked. The slots are what got me to stay — loads of them, from simple 3-reel setups to those crazy 243-ways-to-win ones. I’ve already made the Starburst free spins part of my nightly routine. Plus, there are live dealer games that work well even on slow Wi-Fi, which is a miracle in some parts of Canada. I’ll be sticking with this one for a while. [1]: https://casino-niagara-canada.com
maazkhalid092
maazkhalid092 posted this 26 April 2025
Intraprendere un viaggio culinario con Sedicipuglia rivela il Italian holiday food cuore delle tradizioni pugliesi. Il sito offre una vasta gamma di ricette che mostrano la dedizione della regione alla cucina sana e saporita. Sottolinea l'importanza culturale del cibo in Puglia, evidenziando come le pratiche culinarie siano intrecciate con la storia e il tessuto sociale della regione.
Intraprendere un viaggio culinario con Sedicipuglia rivela il [Italian holiday food][1] cuore delle tradizioni pugliesi. Il sito offre una vasta gamma di ricette che mostrano la dedizione della regione alla cucina sana e saporita. Sottolinea l'importanza culturale del cibo in Puglia, evidenziando come le pratiche culinarie siano intrecciate con la storia e il tessuto sociale della regione. [1]: https://www.sedicipuglia.it/
watsonrobert996
watsonrobert996 posted this 26 April 2025
You can add an off-site link to your WordPress menu. The option is there, but it's just not very obvious at first glance. To do this, go to your WordPress dashboard and navigate to Appearance > Menus. On the left-hand side, you’ll see a section called Custom Links. Click on it, then paste your external URL in the field. For example, I added my The Spike Mods link this way https://thespikegamepro.com/). In the Link Text field, type whatever name you want to display in the menu, like "The Spike Mods". After that, just click Add to Menu and don’t forget to hit Save Menu. Your external link should now appear right in your main navigation!
You can add an off-site link to your WordPress menu. The option is there, but it's just not very obvious at first glance. To do this, go to your WordPress dashboard and navigate to Appearance > Menus. On the left-hand side, you’ll see a section called Custom Links. Click on it, then paste your external URL in the field. For example, I added my *The Spike Mods* link this way https://thespikegamepro.com/). In the Link Text field, type whatever name you want to display in the menu, like "The Spike Mods". After that, just click Add to Menu and don’t forget to hit **Save Menu**. Your external link should now appear right in your main navigation!
healthy.roundworm.bvfn
healthy.roundworm.bvfn posted this 26 April 2025
Hey there! I totally get your frustration. It's surprising when a feature you expect, like adding an offsite link to the menu, isn't immediately obvious. I've wrestled with similar things on other platforms. Sometimes, the way they hide it is a bit like navigating the intricate levels of Slope Game – you have to experiment with different approaches and dig around to find the solution.
Hey there! I totally get your frustration. It's surprising when a feature you expect, like adding an offsite link to the menu, isn't immediately obvious. I've wrestled with similar things on other platforms. Sometimes, the way they hide it is a bit like navigating the intricate levels of [Slope Game][1] – you have to experiment with different approaches and dig around to find the solution. [1]: https://slopegame.lol
sandoonfahad
sandoonfahad posted this 12 November 2025
That’s a good question! Adding an offsite link to the menu can be tricky depending on the platform you’re using. Usually, there’s an option to create a custom link or external URL in your menu settings — that’s where you can paste the full link (like https://thespikegamepro.com
) and give it a title. If your builder doesn’t show that option, you might need to check under “Navigation” or “Advanced” settings.
That’s a good question! Adding an offsite link to the menu can be tricky depending on the platform you’re using. Usually, there’s an option to create a custom link or external URL in your menu settings — that’s where you can paste the full link (like https://thespikegamepro.com ) and give it a title. If your builder doesn’t show that option, you might need to check under “Navigation” or “Advanced” settings.
fery68marget
fery68marget posted this 13 November 2025
sounds like you’re working on a website builder (like Wix, Squarespace, WordPress, or similar), and you’re trying to add a link in your site’s navigation menu that points to an external (offsite) page e.g. a link to YouTube, a partner site, etc.
E-ZPassPA
sounds like you’re working on a website builder (like Wix, Squarespace, WordPress, or similar), and you’re trying to add a link in your site’s navigation menu that points to an external (offsite) page e.g. a link to YouTube, a partner site, etc. [E-ZPassPA][1] [1]: https://www.ez-passpa.com
neejaseo
neejaseo posted this 05 January 2026
Very informative post with clear explanations. seo dubai cannot be overstated. Really helpful for understanding this topic better.
seo uae
SEO company in dubai
SEO near me
local seo company in dubai
seo dubai
Very informative post with clear explanations. [seo dubai][1] cannot be overstated. Really helpful for understanding this topic better. [seo uae][2] [SEO company in dubai][3] [SEO near me][4] [local seo company in dubai][5] [seo dubai][6] [1]: https://shaazseoagency.ae/ [2]: https://shaazseoagency.ae/ [3]: https://shaazseoagency.ae/best-seo-company-in-dubai-uae/ [4]: https://shaazseoagency.ae/best-seo-agency-in-dubai/ [5]: https://shaazseoagency.ae/top-local-seo-company-in-dubai/ [6]: https://shaazseoagency.ae/
walker.ethan1989
walker.ethan1989 posted this 24 March 2026
That’s a great question adding offsite links to a menu can definitely feel unintuitive depending on the platform. You might need to use a “custom link” option or manually enter the URL if it’s available. It’s one of those small features that makes a big difference in usabilitykind of like having a private personal trainer Charlotte guiding you through the process step by step.
That’s a great question adding offsite links to a menu can definitely feel unintuitive depending on the platform. You might need to use a “custom link” option or manually enter the URL if it’s available. It’s one of those small features that makes a big difference in usabilitykind of like having a [private personal trainer Charlotte][1] guiding you through the process step by step. [1]: https://thefitnessstudiocharlotte.com/services/personal-training-charlotte-nc/
seoneejadubai
seoneejadubai posted this 30 April 2026
Very informative post with clear explanations. business setup in dubai mainland cannot be overstated. Really helpful for understanding this topic better.
dubai quick setup
Money middle east
business setup in saudi arabia
Very informative post with clear explanations. [business setup in dubai mainland][1] cannot be overstated. Really helpful for understanding this topic better. [dubai quick setup][2] [Money middle east][3] [business setup in saudi arabia][4] [1]: https://dubaiquicksetup.com/company-setup-in-dubai-mainland/ [2]: https://dubaiquicksetup.com/ [3]: https://moneymiddleeast.com/ [4]: https://dubaiquicksetup.com/business-setup-in-saudi-arabia/
