I keep getting the following error when trying to run Themler after installing it on windows 10...
"Permission Denied"
Here is the info from the diagnostic tool:
INFO:Check free disk space...
INFO:Check Services...
INFO:Check Files...
INFO:Check HTTP Server...
INFO:Check url for C:\PROGRA~3\Themler\hd_data\themler_1362472792
INFO: Check is url available: http://localhost:12080/themler_1362472792/startup
INFO: Check is url available: http://localhost:12080/themler_1362472792/wordpress
INFO: Check is url available: http://localhost:12080/themler_1362472792/joomla
INFO:Check INI Files...
INFO:No errors!
======== Content of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
Installing ThemlerMySql
1:Service successfully installed.
Starting ThemlerMySql
The ThemlerMySql service is starting..
The ThemlerMySql service was started successfully.
Checking ThemlerMySql
information_schema
Done
ERROR 1049 (42000) at line 1: Unknown database 'wordpressdb'
ERROR 1049 (42000) at line 1: Unknown database 'magentodb'
ERROR 1049 (42000) at line 1: Unknown database 'prestashopdb'
ERROR 1049 (42000) at line 1: Unknown database 'woocommercedb'
The 'ThemlerApache' service is successfully installed.
Starting ThemlerApache
The ThemlerApache service is starting....
The ThemlerApache service was started successfully.
Done
======== End of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
======== Content of file C:\ProgramData\Themler\logs\Themler_vbs.log ========
Log for USER - Extra User
Log file path - C:\ProgramData\Themler\logs\Themler_vbs.log
Self path = C:\PROGRA~2\Themler\Themler.vbs
Bin dir = C:\PROGRA~2\Themler\bin\
Startup.bat path = C:\PROGRA~2\Themler\bin\startup.bat
Flag isInstallation = True
Program Files 86 folder = C:\Program Files (x86)
Application Data folder = C:\ProgramData
Local Data folder = C:\Users\Extra User\AppData\Local
Command to run startup.bat = cmd /c ""C:\PROGRA~2\Themler\bin\startup.bat" _1362472792"
Install CMS...
Set current folder as startup ( C:\ProgramData\Themler\hd_data\themler_1362472792\startup )...
OK
Install HTML...
OK
Install Wordpress...
OK
Install Joomla...
OK
======== End of file C:\ProgramData\Themler\logs\Themler_vbs.log ========
ERROR:Unable to find file C:\Users\Mark\AppData\Local\Themler\Themler_vbs.log
======== Content of file C:\ProgramData\Themler\logs\apache\error.log ========
PHP Warning: PHP Startup: Unable to load dynamic library 'C:/PROGRA~2/Themler/bin/php/ext\php_ssh2.dll' - The specified module could not be found.\r\n in Unknown on line 0
[Sat Jan 28 09:22:02.319137 2017] [mpm_winnt:notice] [pid 14792:tid 980] AH00455: Apache/2.4.12 (Win32) PHP/5.4.42 configured -- resuming normal operations
[Sat Jan 28 09:22:02.319633 2017] [mpm_winnt:notice] [pid 14792:tid 980] AH00456: Server built: Mar 19 2015 18:23:40
[Sat Jan 28 09:22:02.319633 2017] [mpm_winnt:notice] [pid 14792:tid 980] AH80000: Distributed by: The Apache Haus
[Sat Jan 28 09:22:02.319633 2017] [mpm_winnt:notice] [pid 14792:tid 980] AH80001: Compiled with: Visual Studio 2008
[Sat Jan 28 09:22:02.320137 2017] [core:notice] [pid 14792:tid 980] AH00094: Command line: 'C:\PROGRA~2\Themler\bin\apache\bin\hthemlerd.exe -d C:/Program Files (x86)/Themler/bin/apache'
[Sat Jan 28 09:22:02.387134 2017] [mpm_winnt:notice] [pid 14792:tid 980] AH00418: Parent: Created child process 2576
[Sat Jan 28 09:22:09.712123 2017] [mpm_winnt:notice] [pid 2576:tid 924] AH00354: Child: Starting 64 worker threads.
======== End of file C:\ProgramData\Themler\logs\apache\error.log ========
======== Content of file C:\ProgramData\Themler\logs\mysql\error.log ========
170128 9:21:35 [Note] Plugin 'FEDERATED' is disabled.
170128 9:21:35 InnoDB: The InnoDB memory heap is disabled
170128 9:21:35 InnoDB: Mutexes and rw_locks use Windows interlocked functions
170128 9:21:35 InnoDB: Compressed tables use zlib 1.2.3
170128 9:21:35 InnoDB: Initializing buffer pool, size = 256.0M
170128 9:21:35 InnoDB: Completed initialization of buffer pool
InnoDB: The first specified data file C:\PROGRA~3\Themler\db_data\ibdata1 did not exist:
InnoDB: a new database to be created!
170128 9:21:35 InnoDB: Setting file C:\PROGRA~3\Themler\db_data\ibdata1 size to 10 MB
InnoDB: Database physically writes the file full: wait...
170128 9:21:35 InnoDB: Log file C:\PROGRA~3\Themler\db_data\ib_logfile0 did not exist: new to be created
InnoDB: Setting log file C:\PROGRA~3\Themler\db_data\ib_logfile0 size to 256 MB
InnoDB: Progress in MB: 100 200
170128 9:21:36 InnoDB: Log file C:\PROGRA~3\Themler\db_data\ib_logfile1 did not exist: new to be created
InnoDB: Setting log file C:\PROGRA~3\Themler\db_data\ib_logfile1 size to 256 MB
InnoDB: Doublewrite buffer not found: creating new
InnoDB: Doublewrite buffer created
InnoDB: 127 rollback segment(s) active.
InnoDB: Creating foreign key constraint system tables
InnoDB: Foreign key constraint system tables created
170128 9:21:37 InnoDB: Waiting for the background threads to start
170128 9:21:38 InnoDB: 5.5.42 started; log sequence number 0
170128 9:21:38 [Note] Server hostname (bind-address): '0.0.0.0'; port: 12306
170128 9:21:38 [Note] - '0.0.0.0' resolves to '0.0.0.0';
170128 9:21:38 [Note] Server socket created on IP: '0.0.0.0'.
170128 9:21:38 [Note] Event Scheduler: Loaded 0 events
170128 9:21:38 [Note] C:\PROGRA~2\Themler\bin\mysql\bin\mythemlerd.exe: ready for connections.
Version: '5.5.42-log' socket: '' port: 12306 MySQL Community Server (GPL)
======== End of file C:\ProgramData\Themler\logs\mysql\error.log ========
SUCCESS!
Please copy content and send it to out support team!
