Parallax fixed width image
leora
leora posted this 02 February 2017
Hi Team
If you look here
http://leorahost.co.uk/buildsites/bvs/arterial-work/carotid-stroke-surgery/
you will see 2 images using parallax. (scroll down quite a way get to the second one)
Above each parallax is the full size image so you can see what it looks like.
The parallax images are not showing enough of the image horizontally.
I would like to have the actual image size in width, fixed with in the parallax box.
Then the parallax scroll shows the bottom and top of image.
If you look at the bottom one, with the girl sitting on the river railing/fence. You can only see her shoulder and waist.
You cant see any of the river and cityscape, as the parallax is stretching the image too much.
So can we contain the size of the image, horizontally the size of the box?
How can I control the size of the image when set tpo parallax?
Hi Team If you look here http://leorahost.co.uk/buildsites/bvs/arterial-work/carotid-stroke-surgery/ you will see 2 images **using parallax**. (scroll down quite a way get to the second one) Above each parallax is the full size image so you can see what it looks like. The parallax images are not showing enough of the image horizontally. I would like to have the actual image size in width, fixed with in the parallax box. Then the parallax scroll shows the bottom and top of image. If you look at the bottom one, with the girl sitting on the river railing/fence. You can only see her shoulder and waist. You cant see any of the river and cityscape, as the parallax is stretching the image too much. So can we contain the size of the image, horizontally the size of the box? How can I control the size of the image when set tpo parallax? Thanks
Support Team posted this 06 February 2017
Hello Leora,
the images used as parallax background images are resized a bit.
You may try to adapt the scrolling a bit, but the image won't be scroll from top to bottom anyway when height almost two times larger than container's height.
It scrolls about 1/2 of image height. So in your particular case I'd recommend that you create special image which will be used as background image for the container with parallax background
Hello Leora, the images used as parallax background images are resized a bit. You may try to adapt the scrolling a bit, but the image won't be scroll from top to bottom anyway when height almost two times larger than container's height. It scrolls about 1/2 of image height. So in your particular case I'd recommend that you create special image which will be used as background image for the container with parallax background regards, Aileen
cathitmm
cathitmm posted this 05 September 2017
Hello Aileen,
We are having a similar issue. How best to fix this, are there steps? The picture is the exact size of another image that was used in the same spot. The photo is of a couple walking in a field, but when using Parallax, every attempt to resize the photo ends up with a zoom of the woman's head. One option made the photo too small, but the entire photo was visible. Thank you in advance if you can assist.
Hello Aileen, We are having a similar issue. How best to fix this, are there steps? The picture is the exact size of another image that was used in the same spot. The photo is of a couple walking in a field, but when using Parallax, every attempt to resize the photo ends up with a zoom of the woman's head. One option made the photo too small, but the entire photo was visible. Thank you in advance if you can assist.
Support Team posted this 05 September 2017
This happens because the image with parallax effect enabled has css background-attachment: "fixed". In this case the image is resized depending on the screen size:
https://www.w3schools.com/cssref/pr_background-attachment.asp
This is behavior by default.
Hi, This happens because the image with parallax effect enabled has css background-attachment: "fixed". In this case the image is resized depending on the screen size: https://www.w3schools.com/cssref/pr_background-attachment.asp This is behavior by default. Thank you, Olivia
jalsurgerymedical
jalsurgerymedical posted this 19 August 2025
JAL Surgery offers trusted private surgery Harrow, providing expert care in a modern and comfortable setting. Our experienced surgeons specialize in a wide range of procedures, ensuring personalized treatment tailored to your needs. At JAL Surgery, we focus on safety, precision, and patient satisfaction for the best possible outcomes.
JAL Surgery offers trusted [private surgery Harrow][1], providing expert care in a modern and comfortable setting. Our experienced surgeons specialize in a wide range of procedures, ensuring personalized treatment tailored to your needs. At JAL Surgery, we focus on safety, precision, and patient satisfaction for the best possible outcomes. [1]: https://jalsurgery.com/
leora
leora posted this 19 August 2025
Please Close / Delete my account ASAP
Not deactivate, close ALL
Hello, Please Close / Delete my account ASAP Not deactivate, close ALL Thank you
