Cart Link: Translate or remove "Cart"
engels
engels posted this 02 February 2017
have a look to the attached screenshots: obviously in themler it's not possible only to show the number of items in the cart without "Cart". Having done a lot of search in that forum, "cart" seems to be hardcoded or not in the translation file of woocommerce. To translate it seems to be not as easy as it should be. Or is there a new solution meanwhile?
How to remove "Cart" ????
In Europe most shops only display the number of items nearby a basket icon.
So please, please, please give us another option in the cart link dropdown: basket-icon + number of products on the cart.
But the best solution would be to configure (translate) it on your own.
Any suggestions?
Thanks.
Hi, have a look to the attached screenshots: obviously in themler it's not possible only to show the number of items in the cart without "Cart". Having done a lot of search in that forum, "cart" seems to be hardcoded or not in the translation file of woocommerce. To translate it seems to be not as easy as it should be. Or is there a new solution meanwhile? How to remove "Cart" ???? In Europe most shops only display the number of items nearby a basket icon. So please, please, please give us another option in the cart link dropdown: basket-icon + number of products on the cart. But the best solution would be to configure (translate) it on your own. Any suggestions? Thanks.
oceanite
oceanite posted this 03 February 2017
there is no solution ?
Hello, there is no solution ? Thanks
Support Team posted this 07 February 2017
Hello guys,
Themler theme uses translation function for this "Cart" text in the Cart Link control. If you want to change the Text I suggest that you try changing the translation of this text in translation file.
Most probably the translation file used to translate the text is available in the woocommerce plugin folder/i18n
<path_WP_folder>\wp-content\plugins\woocommerce\i18n\languages\woocommerce.pot
This is the simplest solution.
Hello guys, Themler theme uses translation function for this "Cart" text in the Cart Link control. If you want to change the Text I suggest that you try changing the translation of this text in translation file. Most probably the translation file used to translate the text is available in the woocommerce plugin folder/i18n <path_WP_folder>\wp-content\plugins\woocommerce\i18n\languages\woocommerce.pot This is the simplest solution. regards, Aileen
