Wordpress admin menu bar in Themler
len
len posted this 02 February 2017
Using the Themler desktop, I am seeing the Wordpress admin menu bar above the theme header in Themler when I open a theme to edit. I am not sure how it has got there, how do I remove it?
Support Team posted this 03 February 2017
Hello Len,
Did you update Wordpress to 4.7? If so this is a known issue and it will be fixed in the next Themler update.
Hello Len, Did you update Wordpress to 4.7? If so this is a known issue and it will be fixed in the next Themler update. Sincerely, Nettie, BillionDigital Team
len
len posted this 13 February 2017
Yes, to 4.7.2.
Do you have an estimate when the new version with the fix will be available,
LenW
Yes, to 4.7.2. Do you have an estimate when the new version with the fix will be available, Thanks LenW
Support Team posted this 13 February 2017
Hello Len,
The next update is expected within next two weeks (Beta update).
Hello Len, The next update is expected within next two weeks (Beta update). Sincerely, Nettie, BillionDigital Team
mgauto
mgauto posted this 16 June 2017
Hi! As of Friday June 16th 2017, I still see this bar and no way of removing it. Did this actually get resolved? Or am I just not finding the option to remove it (in which case the UI would be terribly bad)?
Thanks in advance.
Hi! As of Friday June 16th 2017, I still see this bar and no way of removing it. Did this actually get resolved? Or am I just not finding the option to remove it (in which case the UI would be terribly bad)? Thanks in advance.
Support Team posted this 16 June 2017
mgauto,
Please try updating to the latest Beta version. You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at an time.
Please let us know if the issue is still present.
**mgauto**, Please try updating to the latest Beta version. You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at an time. Please let us know if the issue is still present. Sincerely, Nettie, BillionDigital Team
