email setup
samer_zoubi
samer_zoubi posted this 04 February 2017
Dears,
I'm designing a wordpress site, and I tried to configure the site to send email by using "Easy WP SMTP".
I configured the plugin by using hotmail and gmail smtp servers and tried to send a test email but it's give me an error "SMTP connect() failed.", what I have to do to make it working ?
Best regards,
Samer
Dears, I'm designing a wordpress site, and I tried to configure the site to send email by using "Easy WP SMTP". I configured the plugin by using hotmail and gmail smtp servers and tried to send a test email but it's give me an error "SMTP connect() failed.", what I have to do to make it working ? Best regards, Samer
6 Comments
Support Team posted this 04 February 2017
Please try it with the default WP theme to see if the issue is related to the Themler theme.
Hi, Please try it with the default WP theme to see if the issue is related to the Themler theme. Sincerely, Hella
samer_zoubi
samer_zoubi posted this 06 February 2017
Dears,
I tried it with new wrdpress installation and it works.
I did some changes on the configuration and new message appears "Extension missing: openssl"
Best regards,
Samer
Dears, I tried it with new wrdpress installation and it works. I did some changes on the configuration and new message appears "Extension missing: openssl" Best regards, Samer
Support Team posted this 08 February 2017
Hello Samer,
the reported error is related to PHP and server settings, but not to the theme. Please follow this article http://www.codescafe.com/how-to-fix-the-issue-openssl-extension-is-missing-in-the-right-way/
Hello Samer, the reported error is related to PHP and server settings, but not to the theme. Please follow this article http://www.codescafe.com/how-to-fix-the-issue-openssl-extension-is-missing-in-the-right-way/ Regards, Aileen
samer_zoubi
samer_zoubi posted this 09 February 2017
Dear Aileen,
I didn't published the website on any server yet, I'm using the PHP, Apache and mysql within the Themler setup.
I found php.ini and I removed the comment on the line extension=php_openssl.dll and restart the apache server from windows services.
The same error is appears.
Best regards,
Samer
Dear Aileen, I didn't published the website on any server yet, I'm using the PHP, Apache and mysql within the Themler setup. I found php.ini and I removed the comment on the line extension=php_openssl.dll and restart the apache server from windows services. The same error is appears. Best regards, Samer
Support Team posted this 09 February 2017
Hello Samer,
I suppose that this is configuration issue and it does not related to the theme. Please activate one of default WP themes now and test sending email. In case the error persists please look for solution at WP related forums. Or contact your hosting administrator about the error.
Hello Samer, I suppose that this is configuration issue and it does not related to the theme. Please activate one of default WP themes now and test sending email. In case the error persists please look for solution at WP related forums. Or contact your hosting administrator about the error. regards, Aileen
Steve Rodrich
Steve Rodrich posted this 2 weeks ago
If the settings are correct but the error persists, ask your hosting provider whether outgoing SMTP connections are blocked and review the detailed error logs in Easy WP SMTP.
You can also consider a dedicated SMTP service provider such as iDealSMTP for sending website notifications, contact-form messages, and other transactional emails, provided its configuration is compatible with your hosting environment.
Whichever solution you choose, configure proper authentication and domain records such as SPF and DKIM to support reliable email delivery.
If the settings are correct but the error persists, ask your hosting provider whether outgoing SMTP connections are blocked and review the detailed error logs in Easy WP SMTP. You can also consider a dedicated SMTP service provider such as iDealSMTP for sending website notifications, contact-form messages, and other transactional emails, provided its configuration is compatible with your hosting environment. Whichever solution you choose, configure proper authentication and domain records such as SPF and DKIM to support reliable email delivery.
