Hi ,
Can you retrieve the ticket 116848 about section background ?
When i follow your answer and choose 'default' there is a white page "default template is disabeld". I prbably do somthing wrong ?
Here is you answer out retrived out of ticket 116848
Hello Alain,
Background color.
The background color should be specified for the Section. Open the Default template and add Section Background
Hi , Can you retrieve the ticket 116848 about section background ? When i follow your answer and choose 'default' there is a white page "default template is disabeld". I prbably do somthing wrong ? Here is you answer out retrived out of ticket 116848 Hello Alain, Background color. The background color should be specified for the Section. Open the Default template and add Section Background SectionBG.png
