I have imported the Travel world them to Themler and the menu and theme looks great. with a menu and sub menu showing. However when I insert/replace another horizontal menu the menu in it's container says "Region 'Horizontal Menu 3' is emptyl"
This does not help when designing, so how do I get the menu to display in themler.
So I also Publish and look at the live preview and the same is the case the travel world theme menu is populated and the new inserted menu shows this same message.
Therefore I go into the CMS and look at the blocks and I have Horizontal Menu 1 (with content set as main menu) and Horizontal Menu 3 (with message saying "no blocks in this region") . I therefore change Horizontal Menu 1 main menu to from Horizontal Menu 1 to 3 . and the menu and messages swap regions. (possibly main menu can only appear once). However when I look at live preview it takes me to /drupal/?theme=Travel_World and the theme menu is fine but if I look at /drupal/?theme=Travel_World i get the new menu working fine (but neither at the same time) and whatever I do I cant see the new menu working in the themler design. Can I adjust the content for the blocks in Themeler.
So essentially, how do I get the new menu working in design and live preview at the same time.
Hi, I have imported the Travel world them to Themler and the menu and theme looks great. with a menu and sub menu showing. However when I insert/replace another horizontal menu the menu in it's container says "Region 'Horizontal Menu 3' is emptyl" This does not help when designing, so how do I get the menu to display in themler. So I also Publish and look at the live preview and the same is the case the travel world theme menu is populated and the new inserted menu shows this same message. Therefore I go into the CMS and look at the blocks and I have Horizontal Menu 1 (with content set as main menu) and Horizontal Menu 3 (with message saying "no blocks in this region") . I therefore change Horizontal Menu 1 main menu to from Horizontal Menu 1 to 3 . and the menu and messages swap regions. (possibly main menu can only appear once). However when I look at live preview it takes me to /drupal/?theme=Travel_World and the theme menu is fine but if I look at /drupal/?theme=Travel_World i get the new menu working fine (but neither at the same time) and whatever I do I cant see the new menu working in the themler design. Can I adjust the content for the blocks in Themeler. So essentially, how do I get the new menu working in design and live preview at the same time.
