Custom fields 4 all
giulianos
giulianos posted this 08 February 2017
Good morning,
I'm starting to use Themler which is fantasttico but also very complicated for the hundreds of functions it offers.
It is for years I use joomla and virtuemart and therefore not neglect the CMS only because there are obstacles.
Today while I'm experiencing here is the first big problem.
In a test template I implemented cms addToCart code for the location using the Custom fields plugin 4 all I use for years also because it allows to validate the choice with obligatory.
the problem than the fact that it only works with the drop-down list does not work the obligation of choice. in practice if not made a choice should not go to cart Product.
Not being a programmer in php do not know how to do.
can you help me?
Good morning, I'm starting to use Themler which is fantasttico but also very complicated for the hundreds of functions it offers. It is for years I use joomla and virtuemart and therefore not neglect the CMS only because there are obstacles. Today while I'm experiencing here is the first big problem. In a test template I implemented cms addToCart code for the location using the Custom fields plugin 4 all I use for years also because it allows to validate the choice with obligatory. the problem than the fact that it only works with the drop-down list does not work the obligation of choice. in practice if not made a choice should not go to cart Product. Not being a programmer in php do not know how to do. can you help me?
Support Team posted this 09 February 2017
Sorry, the description is not completely clear. Could you please provide a link to the page where it does not work with the Themler theme and also to the page where it works as it should with another theme. Maybe some screen shots will be also helpful.
Hi, Sorry, the description is not completely clear. Could you please provide a link to the page where it does not work with the Themler theme and also to the page where it works as it should with another theme. Maybe some screen shots will be also helpful. Sincerely, Hella
