theme is not working fine on ipad and iphone
lola2
lola2 posted this 10 February 2017
hello,
i would like to ask for urgent support regarding the themes created with themler in general for output on ipad and iphone.
accutally, for ipad and iphone doesnt work.
i have created a blog. www.kräuterkraft.info
can you please give me some input what to do, as my client is waiting urgent for an answer. thank you very much,
andrea
hello, i would like to ask for urgent support regarding the themes created with themler in general for output on ipad and iphone. accutally, for ipad and iphone doesnt work. i have created a blog. www.kräuterkraft.info can you please give me some input what to do, as my client is waiting urgent for an answer. thank you very much, regards, andrea
Support Team posted this 14 February 2017
Please try to clear the sure cache. If that does not help, try to switch off all the plug-ins to see if that helps.
Hi, Please try to clear the sure cache. If that does not help, try to switch off all the plug-ins to see if that helps. Sincerely, Hella
lola2
lola2 posted this 14 February 2017
thanks but I don't think this is the matter as the site works fine.
What I wantet to know is, ..
is Themler compatible with safari browser and ipad and iphone browsers.
Andrea
Hello, thanks but I don't think this is the matter as the site works fine. What I wantet to know is, .. is Themler compatible with safari browser and ipad and iphone browsers. Regards Andrea
Support Team posted this 15 February 2017
Themler is compatible with Safari and iOS and themes are working fine usually. So that's why I was asking you to switch off the plug-ins to see if one of them is causing the issue.
Hi, Themler is compatible with Safari and iOS and themes are working fine usually. So that's why I was asking you to switch off the plug-ins to see if one of them is causing the issue. Sincerely, Hella
samkonstassmith
samkonstassmith posted this 03 January 2026
Theme issues on iPad and iPhone often come down to how the layout handles mobile Safari and iOS-specific constraints. Checking responsive breakpoints, viewport meta tags, and CSS media queries is a good starting point, since desktop themes can break on smaller screens. JavaScript errors that only appear on iOS can also block proper rendering, so testing in Safari developer tools helps. Another angle is iOS system restrictions, especially when users try customizations after desbloquear iphone, as modified system settings can affect how themes load and behave. Reviewing theme compatibility with current iOS versions and running a clean test on an unmodified device usually gives clearer answers for clients waiting on a fix.
Theme issues on iPad and iPhone often come down to how the layout handles mobile Safari and iOS-specific constraints. Checking responsive breakpoints, viewport meta tags, and CSS media queries is a good starting point, since desktop themes can break on smaller screens. JavaScript errors that only appear on iOS can also block proper rendering, so testing in Safari developer tools helps. Another angle is iOS system restrictions, especially when users try customizations after [desbloquear iphone][1], as modified system settings can affect how themes load and behave. Reviewing theme compatibility with current iOS versions and running a clean test on an unmodified device usually gives clearer answers for clients waiting on a fix. [1]: https://bamug.com/desbloquear-un-iphone-gratis-trucos-y-consejos-para-lograrlo-con-exito/
