Roll up responsive phone menu on submenu item selection
APC
APC posted this 15 February 2017
Hi all,
On a phone responsive menu, when I select a submenu item, the menu doesn't auto roll up to his original position.
I would like to know how to do this.
Thank you for your reply.
Regards, Evelyne.
Hi all, On a phone responsive menu, when I select a submenu item, the menu doesn't auto roll up to his original position. I would like to know how to do this. Thank you for your reply. Regards, Evelyne.
Support Team posted this 16 February 2017
When you click on the menu subitem and that page is loaded, the menu is collapsed into the original state. Please explain your request in more details.
Hi, When you click on the menu subitem and that page is loaded, the menu is collapsed into the original state. Please explain your request in more details. Sincerely, Hella
APC
APC posted this 16 February 2017
Hi Hella,
Thanks for reply.
Actually, the menu appears on a one page website and every links on submenu item are linked to anchors on the page.
Unfortunately, when i select a submenu item, the menu is not collapsed into the original state...
Hope it helps.
Our dev website is available on the internet, how could i send you the url ?
Evelyne
> Hi, > > When you click on the menu subitem and that page is loaded, the menu is collapsed into the original state. Please explain your request in more details. > > Sincerely, > Hella Hi Hella, Thanks for reply. Actually, the menu appears on a one page website and every links on submenu item are linked to anchors on the page. Unfortunately, when i select a submenu item, the menu is not collapsed into the original state... Hope it helps. Our dev website is available on the internet, how could i send you the url ? Regards, Evelyne
Thanks for the explanation, I understand what you mean now. You can not collapse menu if the menu items are anchors. You can try to search for some custom code over the internet that will implement such functionality.
Hi, Thanks for the explanation, I understand what you mean now. You can not collapse menu if the menu items are anchors. You can try to search for some custom code over the internet that will implement such functionality. Sincerely, Hella
APC
Thanks for quick reply,
I already googled but did not find anything interesting.
May be the responsive-nav js plugin but don't know how to use with themler/wordpress. Any idea about that or another solution ?
Evelyne
Thanks for quick reply, I already googled but did not find anything interesting. May be the [responsive-nav js][1] plugin but don't know how to use with themler/wordpress. Any idea about that or another solution ? Regards, Evelyne [1]: http://responsive-nav.com/
Link and script can be added under the Home >> Settings >> Additional HEAD HTML. The HTML code for the menu can be added as the HTML control.
Hi, Link and script can be added under the Home >> Settings >> Additional HEAD HTML. The HTML code for the menu can be added as the HTML control. Sincerely, Hella
APC
Thanks for all... Working fine now
But now I've got another issue.
I've opened a new question about it here : http://answers.themler.com/questions/120458/hover-effect-on-1st-menu-item
If you can help, it will be great ! :)
Evelyne
Thanks for all... Working fine now But now I've got another issue. I've opened a new question about it here : http://answers.themler.com/questions/120458/hover-effect-on-1st-menu-item If you can help, it will be great ! :) Regards, Evelyne
Support Team posted this 17 February 2017
We'll respond to your other ticket as soon as possible.
Hi, We'll respond to your other ticket as soon as possible. Sincerely, Hella
