when I start Themler always part log. I also tried to disable the antivirus.
thank you
thank you
ok, I did as you told me.
When I start the new themler out white screen with the word "awaiting response 127.0.0.1 ...."
thank you
Is this a browser screen? If so, please let us know the console error message (F12 >> Console) and also attach the new log file created after the reinstallation.
white screen and the browser bar exits the writing ... and waits.
white screen and the browser bar exits the writing ... and waits.Hello,
It can happen that antivirus or firewall are not disabled completely even if stopping them and are blocking/removing necessary files.
Please try to add the following folder to your antivirus/firewall white list:
C:\Program Files (x86)\Themler\
and try to install and run Themler once again and export the theme.
I disabled the firewall and antivirus. Themler out white screen waiting to 127.0.0.1
I disabled the firewall and antivirus. Themler out white screen waiting to 127.0.0.1Hello,
Please try to open it through a browser using the link like this one (the numbers replaced with XXXXXXXXXX are individual and are the same that are in the folder with themes):
Try different browsers like Firefox, Chrome. Please let us know the result.
there is no themes because the program is not just party ... always comes out waiting 127.0.0.1
there is no themes because the program is not just party ... always comes out waiting 127.0.0.1Hi,
Did you try opening
page in browser directly?
Here themler_XXXXXXXXXX is the name of the Themler folder here:
Usually it works ok.
Themler Team
ok, it works.
But I always have to use this procedure (http://127.0.0.1:12080/themler_3193958811/startup)??
Looks like there is some third-party application that prevents Themler from running directly, but it is hard to find out the details. So as a workaround, please run Themler through the browser - it is fully functional, and the theme can be saved and exported.
I am having the same problem here. This cannot be an isolated issue. I have attached my diagnostics log file
I am having the same problem here. This cannot be an isolated issue. I have attached my diagnostics log filefaithbloom,
Did you please follow the steps on complete reinstallation of Themler from the second post? The procedure should help in your case.
