Messages "#HttpErrorMessage200PHP", "PHP Error" (on Linux) and "FIle upload failed" (on Windows)
bastosignacio
bastosignacio posted this 18 February 2017
In Linux (working on localhost):
When I opened "http://localhost/themes/Untitled/editor/app.html" appears this message: "#HttpErrorMessage200..." (I attached an image). After, when I try to save a change, appears a PHP Error. (I attached an image too)
In Windows (working on Themler software for Windows):
Appears the message "File upload failed" when I try to "create a new theme" (I attached an image)
In Linux (working on localhost): When I opened "http://localhost/themes/Untitled/__editor__/app.html" appears this message: "#HttpErrorMessage200..." (I attached an image). After, when I try to save a change, appears a PHP Error. (I attached an image too) In Windows (working on Themler software for Windows): Appears the message "File upload failed" when I try to "create a new theme" (I attached an image)
bastosignacio
Please, help me :(
Please, help me :(
Support Team posted this 20 February 2017
Unfortunately the reported issue is not quite clear to me.
As i understand you're working with local webserver on Linux system and you're trying to install themler theme and load Themler, right?
Please make sure that /themes folder has recursive read-write permissions. Also please make sure that you have PHP 5.4+ version installed on your server.
Hi, Unfortunately the reported issue is not quite clear to me. As i understand you're working with local webserver on Linux system and you're trying to install themler theme and load Themler, right? Please make sure that /themes folder has recursive read-write permissions. Also please make sure that you have PHP 5.4+ version installed on your server. Thank you, Olivia
eduardobbastos
eduardobbastos posted this 02 September 2024
Eu estou como o mesmo problema! Não permite exportar e nem salvar! Mesmo com chmod -R 777 *
