Hello everyone. I am excited to use Themler. I purchased Pro version. I am purchased prestashop template from template monster. How do I "import from zip"? it is not working when I import the zip file of the theme. It is failing. If there is a reason for this limitation. What is the principle reason for this limitation. It's important to know this as it is a significant limitation. A primary reason I purchased this software was the assumption that I can upload a prestashop theme I've paid hundreds on and can edit it on the fly.
Thank you in advance.
Hello everyone. I am excited to use Themler. I purchased Pro version. I am purchased prestashop template from template monster. How do I "import from zip"? it is not working when I import the zip file of the theme. It is failing. If there is a reason for this limitation. What is the principle reason for this limitation. It's important to know this as it is a significant limitation. A primary reason I purchased this software was the assumption that I can upload a prestashop theme I've paid hundreds on and can edit it on the fly. Thank you in advance.Last edited 20 February 2017 by yorktown1985
