Manu and submenu
jacop
jacop posted this 23 February 2017
Hello.
I want to have:
1) One item of menu without article
2) submenu to 1) with list of articles
BUT
When I move the pointer of mouse I want to see submenu without click on it.
Please step by step instructions.
Hello. I want to have: 1) One item of menu without article 2) submenu to 1) with list of articles BUT When I move the pointer of mouse I want to see submenu without click on it. Please step by step instructions.
26 Comments
Support Team posted this 24 February 2017
The Horizontal menu control displays subitems on hover by default.
In the same works Vertical menu.
This is default functionality which does not require any additional settings.
Could you please describe in some details the issue you faced with menu. A few screenshots or a link to the problem page should be helpful.
Hi, The Horizontal menu control displays subitems on hover by default. In the same works Vertical menu. This is default functionality which does not require any additional settings. Could you please describe in some details the issue you faced with menu. A few screenshots or a link to the problem page should be helpful. Thank you, Olivia
jacop
jacop posted this 24 February 2017
No, it doesn't work.
I have to have the same effect like e.g. https://goo.gl/O2VPJN
without clicking but only move the cursor over menu I want to see submenu.
I have enabled Hover Transition feature.
Please give me a full instruction what should be enabled or disabled.
You haven't given us a documentation so I ask for full guide.
No, it doesn't work. I have to have the same effect like e.g. https://goo.gl/O2VPJN without clicking but only move the cursor over menu I want to see submenu. I have enabled Hover Transition feature. Please give me a full instruction what should be enabled or disabled. You haven't given us a documentation so I ask for full guide.
Support Team posted this 25 February 2017
Please provide an access to the site back end so we could review the settings. Case is private now. Submenus do appear on hover in Themler menu by default.
Hi, Please provide an access to the site back end so we could review the settings. Case is private now. Submenus do appear on hover in Themler menu by default. Sincerely, Hella
jacop
jacop posted this 25 February 2017
I use Themler on XAMPP on the virtual machine, because your "installation" version doesn't work well. I have had many problems with it.
I'm guessing that I'm not alone with my problem, so please create screenshots and paste here.
And please disable "Private/Support"
I use Themler on XAMPP on the virtual machine, because your "installation" version doesn't work well. I have had many problems with it. I'm guessing that I'm not alone with my problem, so please create screenshots and paste here. And please disable "Private/Support"
Support Team posted this 27 February 2017
The issue is related to some specific settings and we need to review them. Please export the theme with the content and editor included and attach it to the ticket.
Hi, The issue is related to some specific settings and we need to review them. Please export the theme with the content and editor included and attach it to the ticket. Sincerely, Hella
jacop
jacop posted this 27 February 2017
Please describe which one?
I want to be able to do in next project.
And I don't want to export/import content, because I work on one instance from the beginning to the end.
Again: please disable "Private/Support"
Please describe which one? I want to be able to do in next project. And I don't want to export/import content, because I work on one instance from the beginning to the end. Again: please disable "Private/Support"
Support Team posted this 28 February 2017
OK, case is public. But I can not help you if you do not provide a theme. The menu should auto drop-down by the default, that does not require any additional settings. So if that is not working on your end, then you have added some strange settings and we'll need to find them. I can not tell what you have done without looking on your theme. Or we do not understand each other and you need some other functionality.
Hi, OK, case is public. But I can not help you if you do not provide a theme. The menu should auto drop-down by the default, that does not require any additional settings. So if that is not working on your end, then you have added some strange settings and we'll need to find them. I can not tell what you have done without looking on your theme. Or we do not understand each other and you need some other functionality. Sincerely, Hella
jacop
jacop posted this 28 February 2017
So please put here screenshots with good/default configuration, because it is strange for me that you make such difficulties with it.
jacop
As you can notice in 1.jpg I'm on O NAS site and I move cursor over menu ZABIEGI. Then below ZABIEGI should be visible submenu. I have to click on ZABIEGI then submenu appears.
As you can notice in 1.jpg I'm on O NAS site and I move cursor over menu ZABIEGI. Then below ZABIEGI should be visible submenu. I have to click on ZABIEGI then submenu appears. I have to have the same effect like e.g. https://goo.gl/O2VPJN without clicking but only move the cursor over menu I want to see submenu.
Support Team posted this 01 March 2017
Looks strange. Maybe the submenus do drop down but are covered by the image. Please click on the Horizontal Menu control, when it's options appear on the top ribbon, click on any more options button in the options and then the right panel will appear. Set the z-index value to some high value like 10000. If that does not help, then go to each control that includes your menu. On the bottom of the application screen there will be a path like breadcrumbs (Header >> Section >> Container >> Horizontal Menu). So click on Container first, do the same operations with z-index, then on Section and so on. If that still does not help, attach your exported theme as this problem is theme-specific and it will be easier to review the theme settings than guess what options to edit.
Hi, Looks strange. Maybe the submenus do drop down but are covered by the image. Please click on the Horizontal Menu control, when it's options appear on the top ribbon, click on any more options button in the options and then the right panel will appear. Set the `z-index` value to some high value like 10000. If that does not help, then go to each control that includes your menu. On the bottom of the application screen there will be a path like breadcrumbs (Header >> Section >> Container >> Horizontal Menu). So click on Container first, do the same operations with z-index, then on Section and so on. If that still does not help, attach your exported theme as this problem is theme-specific and it will be easier to review the theme settings than guess what options to edit. Sincerely, Hella
jacop
jacop posted this 01 March 2017
I did like you had suggested without problem-solving.
This is a bigger problem than I thought.
Now you have a hard nut to crack!
Please contact with Aileen (your collogue).
Now I know why you don't have a documentation of your software! Because this is a test not final software!
You are testing it on us (customer) for our money! It is not fair!
I did like you had suggested without problem-solving. This is a bigger problem than I thought. Now you have a hard nut to crack! Please contact with Aileen (your collogue). Now I know why you don't have a documentation of your software! Because this is a test not final software! You are testing it on us (customer) for our money! It is not fair!
Support Team posted this 02 March 2017
Hello Jacek,
regarding the problem with menu. Please refer to my response in topic http://answers.themler.com/questions/121985/problem-after-migration
Hello Jacek, regarding the problem with menu. Please refer to my response in topic http://answers.themler.com/questions/121985/problem-after-migration regards, Aileen
kg900830
kg900830 posted this 15 May 2025
The Lightweight Hex Frame Canopy from Birttani is a premium outdoor shelter designed for both durability and portability. Ideal for events, markets, and recreational use, this canopy features a robust hexagonal aluminum frame that ensures stability while remaining lightweight for easy setup and transport. The canopy's design combines strength with convenience, making it a reliable choice for various outdoor activities.
The **[Lightweight Hex Frame Canopy][1]** from Birttani is a premium outdoor shelter designed for both durability and portability. Ideal for events, markets, and recreational use, this canopy features a robust hexagonal aluminum frame that ensures stability while remaining lightweight for easy setup and transport. The canopy's design combines strength with convenience, making it a reliable choice for various outdoor activities. [1]: https://birttani.com/product/tenda-hex-aluminum-10-x-10/
kg900830
In der heutigen digitalen Welt gewinnt das Fernsehen über das Internet immer mehr an Bedeutung. Ein zuverlässiger IPTV Anbieter ist dabei der Schlüssel, um hochwertiges Streaming-Erlebnis mit einer großen Auswahl an TV-Sendern und Filmen zu genießen. Auf https://siptvkaufen.de finden Sie einen vertrauenswürdigen IPTV Anbieter, der Ihnen zahlreiche Vorteile bietet – von HD-Qualität über stabile Verbindungen bis hin zu einem vielfältigen Programmangebot. Egal, ob Sie aktuelle Serien, Sportübertragungen oder internationale Kanäle bevorzugen, ein guter IPTV Anbieter sorgt dafür, dass Sie Ihre Lieblingsinhalte jederzeit und überall genießen können.
In der heutigen digitalen Welt gewinnt das Fernsehen über das Internet immer mehr an Bedeutung. Ein zuverlässiger IPTV Anbieter ist dabei der Schlüssel, um hochwertiges Streaming-Erlebnis mit einer großen Auswahl an TV-Sendern und Filmen zu genießen. Auf https://siptvkaufen.de finden Sie einen vertrauenswürdigen **[IPTV Anbieter][1]**, der Ihnen zahlreiche Vorteile bietet – von HD-Qualität über stabile Verbindungen bis hin zu einem vielfältigen Programmangebot. Egal, ob Sie aktuelle Serien, Sportübertragungen oder internationale Kanäle bevorzugen, ein guter IPTV Anbieter sorgt dafür, dass Sie Ihre Lieblingsinhalte jederzeit und überall genießen können. [1]: https://siptvkaufen.de
kg900830
Ein Versicherungsvergleich ist heute wichtiger denn je, um die optimale Absicherung zu fairen Konditionen zu finden. Auf der Plattform versicherungsvergleiche.de können Nutzer bequem und schnell verschiedene Versicherungsangebote miteinander vergleichen. Ob Haftpflicht, Kfz-, oder Lebensversicherung – ein gründlicher Versicherungsvergleich hilft dabei, Kosten zu sparen und gleichzeitig den passenden Schutz für die individuellen Bedürfnisse zu wählen. So behalten Sie stets den Überblick und finden die besten Tarife auf dem Markt.
Ein Versicherungsvergleich ist heute wichtiger denn je, um die optimale Absicherung zu fairen Konditionen zu finden. Auf der Plattform versicherungsvergleiche.de können Nutzer bequem und schnell verschiedene Versicherungsangebote miteinander vergleichen. Ob Haftpflicht, Kfz-, oder Lebensversicherung – ein gründlicher **[Versicherungsvergleich][1]** hilft dabei, Kosten zu sparen und gleichzeitig den passenden Schutz für die individuellen Bedürfnisse zu wählen. So behalten Sie stets den Überblick und finden die besten Tarife auf dem Markt. [1]: https://versicherungsvergleiche.de/
pasoxem788
pasoxem788 posted this 15 May 2025
Greeting everyone. I have recently started playing online slot machines on this site in Canada - Wild Casino . and I like this site very much because on this site I found many features for playing online slot machines, and on this site I was able to play all the quality and reliable online slot machines!
Greeting everyone. I have recently started playing online slot machines on this site in Canada - [Wild Casino][1] . and I like this site very much because on this site I found many features for playing online slot machines, and on this site I was able to play all the quality and reliable online slot machines! [1]: https://wild-casino-canada.com
idmcrack505
idmcrack505 posted this 15 May 2025
https://idmcrack.cloud/
then.moose.lbbp
then.moose.lbbp posted this 16 May 2025
Discover endless puzzle fun with Wordle Unlimited! Challenge yourself with unlimited word guessing and sharpen your mind every day. Play now at https://wordleunlimited.click/ and enjoy countless hours of brain-boosting entertainment!
Discover endless puzzle fun with [Wordle Unlimited][1]! Challenge yourself with unlimited word guessing and sharpen your mind every day. Play now at https://wordleunlimited.click/ and enjoy countless hours of brain-boosting entertainment! [1]: https://wordleunlimited.click/
kg900830
kg900830 posted this 18 May 2025
Ghosts have long fascinated and unsettled us—spectral figures caught between worlds, echoing unresolved stories and emotions. At Kandy Kitten Alternative, the mysterious allure of ghosts finds a creative outlet in bold, gothic-inspired fashion and alternative aesthetics. This unique shop taps into the haunting beauty of the paranormal, offering styles that resonate with those who embrace the darker, more enigmatic sides of life. Whether you're drawn to ghosts for their eerie elegance or symbolic depth, Kandy Kitten Alternative provides an expressive way to wear your fascination.
Ghosts have long fascinated and unsettled us—spectral figures caught between worlds, echoing unresolved stories and emotions. At Kandy Kitten Alternative, the mysterious allure of **[ghosts][1]** finds a creative outlet in bold, gothic-inspired fashion and alternative aesthetics. This unique shop taps into the haunting beauty of the paranormal, offering styles that resonate with those who embrace the darker, more enigmatic sides of life. Whether you're drawn to ghosts for their eerie elegance or symbolic depth, Kandy Kitten Alternative provides an expressive way to wear your fascination. [1]: https://kandykittenalternative.co.uk/
kg900830
When it comes to safeguarding your property and ensuring compliance with fire safety regulations in Walsall, RB Services Ltd stands out as a trusted partner. Specializing in fire protection services, Fire protection Walsall they offer comprehensive solutions tailored to meet the unique needs of businesses and property owners in the area.
When it comes to safeguarding your property and ensuring compliance with fire safety regulations in Walsall, RB Services Ltd stands out as a trusted partner. Specializing in fire protection services, **[Fire protection Walsall][1]** they offer comprehensive solutions tailored to meet the unique needs of businesses and property owners in the area. [1]: https://www.rbtesting.com/fire-extinguisher-servicing-walsall/
