Default Styles Bug
shaulhadar
shaulhadar posted this 14 August 2014
Hello Themeler Team. I have encountered two bugs with the heading styles and the default styles in themeler.
I tried to make a line to be H1, so i choose the option of H1, and what happened is that the text stays the same size, but suddenly has margins above and beyond the text.
So I went to "Default Styles" page to try and fix it, and currently the page doesn't load, and gave me a server error.
Please check it out when you have a sec..
Shaul.
Hello Themeler Team. I have encountered two bugs with the heading styles and the default styles in themeler. I tried to make a line to be H1, so i choose the option of H1, and what happened is that the text stays the same size, but suddenly has margins above and beyond the text. So I went to "Default Styles" page to try and fix it, and currently the page doesn't load, and gave me a server error. Please check it out when you have a sec.. Thanks, Shaul.
Support Team posted this 14 August 2014
Hello Shaul,
I couldn't reproduce any of the reported issues, so some details would be helpful. What is the control you are trying to change text to H1 in? Currently for example for the text in the Text control the text changes the style as it should.
Hello Shaul, I couldn't reproduce any of the reported issues, so some details would be helpful. What is the control you are trying to change text to H1 in? Currently for example for the text in the Text control the text changes the style as it should. Sincerely, BillionDigital Team
shaulhadar
shaulhadar posted this 18 August 2014
I was trying to add it inside a text element..... I will check it again and let you know about the details of the issue..
thanks for your time.
I was trying to add it inside a text element..... I will check it again and let you know about the details of the issue.. thanks for your time.
Support Team posted this 18 August 2014
I've failed to reproduce this issue too.
Ok. Please keep us posted about the progress.
Hello I've failed to reproduce this issue too. Ok. Please keep us posted about the progress. Thank you, Olivia
