How to customize WordPress Plugin installation?
grabbitmediait
grabbitmediait posted this 01 March 2017
I have a WordPress plugin which I've built. This plugin contains a Pro version.
When user sign-up for the Pro version, he is getting a unique key.php file which he required to replace in the plugin directory.
The problem is when Pro users upgrade to newer versions, the key.php file is deleted and they need to re-upload it (every upgrade).
Is there any way to specify that this file shouldn't be deleted by WordPress installation process?
I have a WordPress plugin which I've built. This plugin contains a Pro version. When user sign-up for the Pro version, he is getting a unique key.php file which he required to replace in the plugin directory. The problem is when Pro users upgrade to newer versions, the key.php file is deleted and they need to re-upload it (every upgrade). Is there any way to specify that this file shouldn't be deleted by WordPress installation process?
Support Team posted this 01 March 2017
Sorry, I'm not sure I understand you. How you issue is related to the Themler theme?
Hi, Sorry, I'm not sure I understand you. How you issue is related to the Themler theme? Sincerely, Hella
