Joomla and VirtueMart
mmixsetup
mmixsetup posted this 01 March 2017
Hi when starting either Joomla or VirtueMart it takes ages to load.
It just sits there for like 1 minute or so then starts to load and then updates.
It does this every time and updates.
Every other CMS like HTML,WordPress and all the others work fine.
Hi when starting either Joomla or VirtueMart it takes ages to load. It just sits there for like 1 minute or so then starts to load and then updates. It does this every time and updates. Every other CMS like HTML,WordPress and all the others work fine.
Support Team posted this 01 March 2017
Do you work with Themler for Windows? Does the issue happen with a new Joomla theme?
If so, please follow the steps below:
1. Backup all theme folders somewhere on your computer if there are any. Export them or copy manually from the theme folder. The path is shown in the Theme Management screen after selecting some CMS, for example, C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla.
7. Download latest version of Themler for Windows from themler.com, install it and try to start with Themler for Joomla and create a theme.
8. Update the theme if there are updates for it and save it.
9. Reload Themler and try to run this theme.
Hello, Do you work with Themler for Windows? Does the issue happen with a new Joomla theme? If so, please follow the steps below: 1. Backup all theme folders somewhere on your computer if there are any. Export them or copy manually from the theme folder. The path is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla`. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Temporarily disable antivirus and firewall. 7. Download latest version of Themler for Windows from themler.com, install it and try to start with Themler for Joomla and create a theme. 8. Update the theme if there are updates for it and save it. 9. Reload Themler and try to run this theme. Please let us know the result. Sincerely, Nettie, BillionDigital Team
