quote system
mmixsetup
mmixsetup posted this 01 March 2017
Hi there I am trying to make a website and on it I want a page which has about 6 products and a length then it will give the person a quote.
Can Themler do this?
If it can what do I use to create one?
Hi there I am trying to make a website and on it I want a page which has about 6 products and a length then it will give the person a quote. Can Themler do this? If it can what do I use to create one?
Support Team posted this 01 March 2017
Sorry, your explanation is not clear. Maybe you could provide a link to the example site. Or attach a screen shot of what you want to create.
Hi, Sorry, your explanation is not clear. Maybe you could provide a link to the example site. Or attach a screen shot of what you want to create. Sincerely, Hella
mmixsetup
mmixsetup posted this 02 March 2017
Hi here is a simple image I just drew of what I am thinking of.
The client would tick the box for the item they would like then they would type in the distance and they would receive the quote.
Michael
Hi here is a simple image I just drew of what I am thinking of. The client would tick the box for the item they would like then they would type in the distance and they would receive the quote. Regards Michael
Support Team posted this 02 March 2017
As I understand, you need some kind of form that will have several check boxes and then calculate the result. Themler does not implement the functionality of the form, only adds the controls like input, check box and button. Functionality should be added as the code. Or you can search for the appropriate plug-in over the internet.
http://answers.themler.com/articles/71585/form
Hi, As I understand, you need some kind of form that will have several check boxes and then calculate the result. Themler does not implement the functionality of the form, only adds the controls like input, check box and button. Functionality should be added as the code. Or you can search for the appropriate plug-in over the internet. http://answers.themler.com/articles/71585/form Sincerely, Hella
mmixsetup
If i want to code some javascript to execute the form can I add this to the theme in Themler with the form or do I have to make the form link to an external javascript file?
Michael
If i want to code some javascript to execute the form can I add this to the theme in Themler with the form or do I have to make the form link to an external javascript file? Regards Michael
I'm not sure what is the best way to make a complicated form, but you can even insert the code of the whole form itself without adding the input and button elements in Themler. The code of the whole form can be added into the HTML control.
Hi, I'm not sure what is the best way to make a complicated form, but you can even insert the code of the whole form itself without adding the input and button elements in Themler. The code of the whole form can be added into the HTML control. Sincerely, Hella
mmixsetup
Thank you.
You can close this now.
Thank you. You can close this now.
Support Team posted this 03 March 2017
You are welcome. Feel free to contact us again.
You are welcome. Feel free to contact us again. Sincerely, Hella
