I have juste updated Themler and now I have this message :
You can't edit this theme because Themler requires PHP version 5.3.0 or higher. You are running version 5.2.17.
Please upgrade your PHP version to continue.
Check in your Cpanel if there is new version. All hosting providers offer newer.
Check in your Cpanel if there is new version. All hosting providers offer newer.It would be "helpfull" if Themler team message has some kind of alert :
Please upgrade to php 5.3.0 or higher before updating your Themler theme...!!!
It would be "helpfull" if Themler team message has some kind of alert : Please upgrade to php 5.3.0 or higher before updating your Themler theme...!!!Oliver,
We apologize for the inconvenience.
Yes, starting with this update Themler requires PHP version 5.3.0 or higher.
We hope that you will not have difficulties with updating PHP.
This might be an issue for creating multiple website for clients. For every hosting account I would have to request a server upgrade.
This might be an issue for creating multiple website for clients. For every hosting account I would have to request a server upgrade.Hi,
We are sorry for the inconvenience. But the PHP 5.3 version is not a new one and most of the servers are already working on PHP 5.4 and higher.
Will this cause legacy issues with themes designed in Themler or can themes be sold to clients 'as is' and not be updated from when they are installed/therefore not impacted by Themler updates etc?
Will this cause legacy issues with themes designed in Themler or can themes be sold to clients 'as is' and not be updated from when they are installed/therefore not impacted by Themler updates etc?Hello team7 user,
in fact Themler themes could be installed to most WP sites (I see that you're interested in WP themes) without any problem. PHP codes would be compatible with higher PHP versions and as was mentioned before, PHP 5.3 should not cause any issue on most hostings.
I have just updated joomla 3.8.12 and now I have this message :
Since v2.7.0, component requires PHP version 5.6.0 or later. You should upgrade your PHP version first to ensure maximum compatibility and security. Your current PHP version is 5.4.42
Hello, I have just updated joomla 3.8.12 and now I have this message : Since v2.7.0, component requires PHP version 5.6.0 or later. You should upgrade your PHP version first to ensure maximum compatibility and security. Your current PHP version is 5.4.42 Thank youHello,
Themler requirements about PHP version for CMS are the same as required for a specific CMS version on their website. If Themler doesn't work with a specific Joomla version or specific PHP version, please provide some details about the issue.
I'm working with themler for windows- joomla,
when i install component that message is coming.
Do you mean that you install some third-party component while working in Themler desktop? Does the same happen on your live site?
ya,when i'm working in themler desktop i install third-party component, than that message is coming,i can't install the component.
but live site is ok(online with themler template)
Looks like this is because the current PHP version that goes with Themler desktop local Joomla installation, is lower. So we would recommend you, to try installing the component right there, on the live website, or as an alternative solution, or for testing purposes you may try installing both Themler theme and the component on some localhost with the required PHP version.
