Inserir Accordion
augustoleite.nascimento
augustoleite.nascimento posted this 04 March 2017
Good morning, dear,
I noticed that it is possible to insert accordion, but it does not appear in the option> insert> More the accordion option, can you help me please?
Good morning, dear, I noticed that it is possible to insert accordion, but it does not appear in the option> insert> More the accordion option, can you help me please?
8 Comments
Stagger Lee posted this 04 March 2017
It is only for WooCommerce I believe. But I am not sure now.
I tested now and also do not have to WooCommerce, how can we do?
Stagger Lee posted this 05 March 2017
With HTML, or CMS Control and manual code. See on Google, there are many examples. It is called "Panels" sometimes.
Support Team posted this 06 March 2017
Themler does not have the built-in accordion control so the solution is to use custom code in the HTML control.
Hi, Themler does not have the built-in accordion control so the solution is to use custom code in the HTML control. Sincerely, Hella
Gillips
Gillips posted this 3 weeks ago
I realise this is an old post, but just wanted to check if it's still the case that it isn't built in? I can't find it.
If it is now available, how would you set it up within a Joomla article?
Or might the answer be to look for custom code to insert into the article itself?
Thanks for any pointers.
Hi I realise this is an old post, but just wanted to check if it's still the case that it isn't built in? I can't find it. If it is now available, how would you set it up within a Joomla article? Or might the answer be to look for custom code to insert into the article itself? Thanks for any pointers.
Probably, you mean the Accordion control that can be configured under the Default Styles.
The buit-in Accordion is used in these ways:
- Product Detail Tabs control uses Accordion for responsive - tabs are used for desktop.
- For Product Details Tabs in Responsive mode.
- Also, in Joomla, accordion is used for Page Break (Slides) and Single Contact Layout.
For other cases, a custom code and HTML control are used.
Hello, Probably, you mean the Accordion control that can be configured under the Default Styles. The buit-in Accordion is used in these ways: - Product Detail Tabs control uses Accordion for responsive - tabs are used for desktop. - For Product Details Tabs in Responsive mode. - Also, in Joomla, accordion is used for Page Break (Slides) and Single Contact Layout. For other cases, a custom code and HTML control are used. Sincerely, Nettie
Gillips
Gillips posted this 1 weeks ago
Thanks Nettie. Just seen your reply - didn't get notification I don't think.
I have now used a modified Joomla extension and {loadposition} to insert an accordion within my article, but will have a look at the other features you mention.
Thanks Nettie. Just seen your reply - didn't get notification I don't think. I have now used a modified Joomla extension and {loadposition} to insert an accordion within my article, but will have a look at the other features you mention.
This is because the notification comes to the customer created the topic initially, sorry for this.
You are welcome!
Hello, This is because the notification comes to the customer created the topic initially, sorry for this. You are welcome! Nettie
