Can I create a new theme using Themler on Linux?
Suppose, I have created a LAMP server and setup WordPress on it. Now, can I install Themler files in WordPress and start building new theme?
Is something like this possible?
If possible, where from can I download the Themler files that I use directly under WordPress to build new theme?
Can I create a new theme using Themler on Linux? Suppose, I have created a LAMP server and setup WordPress on it. Now, can I install Themler files in WordPress and start building new theme? Is something like this possible? If possible, where from can I download the Themler files that I use directly under WordPress to build new theme?
