In the Themler program the Title lines up perfect like it should, but in the live preview it is not lined up properly - see attached image. Why oh why won't it stay positioned properly like it does in the program? This is not good if you are building a client's site and it does this kind of stuff! Plus if you use the HTML feature to hard code it - the program strips the coding so why do you even offer that?
I am becoming more and more disillusioned with Themler the more I use it. I think even though it helps me develop sites quicker - the continued issues with bugs makes me to unsure about it to utilize it for my business. Maybe I will just have to go back to using Artisteer until you get this further along. I waste so much time on petty things like this that should not be an issue. Very disappointed.
In the Themler program the Title lines up perfect like it should, but in the live preview it is not lined up properly - see attached image. Why oh why won't it stay positioned properly like it does in the program? This is not good if you are building a client's site and it does this kind of stuff! Plus if you use the HTML feature to hard code it - the program strips the coding so why do you even offer that? I am becoming more and more disillusioned with Themler the more I use it. I think even though it helps me develop sites quicker - the continued issues with bugs makes me to unsure about it to utilize it for my business. Maybe I will just have to go back to using Artisteer until you get this further along. I waste so much time on petty things like this that should not be an issue. Very disappointed.
