Errors built pages on THEMLER
Piotr_D
Piotr_D posted this 10 March 2017
I can still get to the why cell site long time to load because more than 1 minute but studied it for errors and please take a look at Google Chrome displays - in Annex file.
Support Team posted this 10 March 2017
As I understand, this is simple HTML website.
Did you edit the theme files manually? The 404 error is related to the fact that theme styles and scripts registered twice and the second registration is not valid and returns 404 error.
Hi, As I understand, this is simple HTML website. Did you edit the theme files manually? The 404 error is related to the fact that theme styles and scripts registered twice and the second registration is not valid and returns 404 error. Thank you, Olivia
Piotr_D
So it is a simple HTML page created with THEMLER. Do not quite understand what to ask, but the main problem is the time to start hand in roaming mode for eg. IPhone and iPad - more than 1 minute when the load.
Piotr_D
http://www.pakodeos.com/test
http://www.pakodeos.com/test/PAKODEOS_17310.zip
http://www.pakodeos.com/test http://www.pakodeos.com/test/PAKODEOS_17310.zip
Support Team posted this 13 March 2017
I checked your theme and tested http://www.pakodeos.com/test/ in FF and Chrome. I do not see any problem with speed with your theme.
Also the pages are loaded in browsers from 2 sec to 5 sec. The speed is OK. From the screenshot you attached I see that page is loaded about 667ms
I also checked the page at iPhone emulator - the page is loaded fast too.
Please try to open the site from different device and/or browser and let us know the results.
Hello, I checked your theme and tested http://www.pakodeos.com/test/ in FF and Chrome. I do not see any problem with speed with your theme. Also the pages are loaded in browsers from 2 sec to 5 sec. The speed is OK. From the screenshot you attached I see that page is loaded about 667ms !image-error-page.png! I also checked the page at iPhone emulator - the page is loaded fast too. Please try to open the site from different device and/or browser and let us know the results. regards, Aileen
Piotr_D
Piotr_D posted this 13 March 2017
I found the problem already and describes it in the topic
http://answers.themler.com/questions/123451/error-export-to-file?page=1
I found the problem already and describes it in the topic http://answers.themler.com/questions/123451/error-export-to-file?page=1
