HTML theme download
swapnil247
swapnil247 posted this 10 March 2017
I have designed a HTML theme and want to export it but unable to find the option. Ive tried "export as" option but it doesnt so anything. I am using themler on a mac.
Support Team posted this 12 March 2017
The export option: File >> Export as ZIP.
If it does not work on your side there is could be an error message. Themler Desktop uses regular browser so you should be able to open browser console (like F12 on Windows). The error message should be available on the Console tab. If you see the message please provide the screenshot of the error message.
Also, if the theme is quite large (with a lot of images) the export can be slow.
Hi, The export option: File >> Export as ZIP. If it does not work on your side there is could be an error message. Themler Desktop uses regular browser so you should be able to open browser console (like F12 on Windows). The error message should be available on the Console tab. If you see the message please provide the screenshot of the error message. Also, if the theme is quite large (with a lot of images) the export can be slow. Thank you, Olivia
