Accordion in Prestashop not working
info1938
info1938 posted this 15 March 2017
Hello!
I've a site (currently in maintenance mode) that doesn't show accordion menu in product tabs on a mobile device. It shows the content from the first tab only. Attached are photos.
Hello! I've a site (currently in maintenance mode) that doesn't show accordion menu in product tabs on a mobile device. It shows the content from the first tab only. Attached are photos.
Support Team posted this 15 March 2017
We're aware about this issue. It should be fixed in the future Themler updates.
In the meantime please try disable Product Tabs responsiveness:
Hi, We're aware about this issue. It should be fixed in the future Themler updates. In the meantime please try disable Product Tabs responsiveness: !product-tabs-resp.png! Thank you, Olivia
info1938
info1938 posted this 16 March 2017
OK, I've disabled the responsive option, currently the tabs are tabs on mobile also (no accordion).
Also for the update I remind that reviews stars are not working :)
Thank you!
OK, I've disabled the responsive option, currently the tabs are tabs on mobile also (no accordion). Also for the update I remind that reviews stars are not working :) Thank you!
Support Team posted this 16 March 2017
Could you please check the last beta update:
http://answers.themler.com/questions/122312/themler-v-358-beta-update-2-march-2017
The issue with rating should be fixed either in this or the next update.
Hi, > Also for the update I remind that reviews stars are not working :) Could you please check the last beta update: http://answers.themler.com/questions/122312/themler-v-358-beta-update-2-march-2017 The issue with rating should be fixed either in this or the next update. Thank you, Olivia
engels
engels posted this 27 October 2017
what about the issue with accordion in product tabs in responsive mode for mobiles?
Any solution meanwhile?
Another question/issue:
Tables in product tabs always have a background in the regular rows (alternate rows background works fine).
Alternate rows no background, table no background, no background anywhere.
But I can't remove colour of each second row.
Can you reproduce that?
Koepi
Hi, what about the issue with accordion in product tabs in responsive mode for mobiles? Any solution meanwhile? Another question/issue: Tables in product tabs always have a background in the regular rows (alternate rows background works fine). Alternate rows no background, table no background, no background anywhere. But I can't remove colour of each second row. Can you reproduce that? Thanks Koepi
Support Team posted this 29 October 2017
No, unfortunately.
But you can disable responsive options of the Product Tabs control and use it as tabs.
Most probably the table uses bootstrap table style. If so please try adding the following code to the Themler Settings >> Additional CSS:
.table-striped > tbody > tr:nth-child(2n+1) > td, .table-striped > tbody > tr:nth-child(2n+1) > th {
background-color: none;
Or change table configuration under the Themler Design tab >> More Styles.
Hi, > what about the issue with accordion in product tabs in responsive mode for mobiles? Any solution meanwhile? No, unfortunately. But you can disable responsive options of the Product Tabs control and use it as tabs. > Tables in product tabs always have a background in the regular rows (alternate rows background works fine). Alternate rows no background, table no background, no background anywhere. But I can't remove colour of each second row. Can you reproduce that? Most probably the table uses bootstrap table style. If so please try adding the following code to the Themler Settings >> Additional CSS: `.table-striped > tbody > tr:nth-child(2n+1) > td, .table-striped > tbody > tr:nth-child(2n+1) > th { background-color: none; }` Or change table configuration under the Themler Design tab >> More Styles. Thank you, Olivia
