Critical CSS
Mark Holland
Mark Holland posted this 17 March 2017
Hi All I am using above the fold plugin for wordpress I have installed the critical css info and still having issues so was wandering if someone could point me in the right direction, I still get the flash of un-styled content when i visit the page.
http://oxydubbers.co.uk/?compare-abtf=4067dc2f15c3bcd3bc6391d8a9978de6
Check the link out the left is what I am seeing when the page loads.
On other sites it seems ok but not with this one.
Any pointers would be appreciated.
Hi All I am using above the fold plugin for wordpress I have installed the critical css info and still having issues so was wandering if someone could point me in the right direction, I still get the flash of un-styled content when i visit the page. http://oxydubbers.co.uk/?compare-abtf=4067dc2f15c3bcd3bc6391d8a9978de6 Check the link out the left is what I am seeing when the page loads. On other sites it seems ok but not with this one. Any pointers would be appreciated.
10 Comments
Mark Holland
it actually seem,s like the background header image is the issue but cant for the life of me work out.
Support Team posted this 17 March 2017
Looks like the plug-in is changing the names of the images in the CSS code. I'm not sure how we could help with this issue.
Hi, Looks like the plug-in is changing the names of the images in the CSS code. I'm not sure how we could help with this issue. Sincerely, Hella
Mark Holland
could you give an example as i cant see it?
I should be able to sort it from here.
Also I have been doing a lot of optimisation work on a lot of my themler templates and I have some ideas for future releases.
  1. In the image editor have an optimisation plugin.
  2. Maybe add some css and java minify plugins
  3. Any other speed options
Thanks Mark
could you give an example as i cant see it? I should be able to sort it from here. Also I have been doing a lot of optimisation work on a lot of my themler templates and I have some ideas for future releases. 1. In the image editor have an optimisation plugin. 2. Maybe add some css and java minify plugins 3. Any other speed options Thanks Mark
Support Team posted this 20 March 2017
Sorry for the delay. Now the link does not load any styles for the left site example.
As for your suggestions, thanks, but we are already minifying the exported css and js files.
Hi, Sorry for the delay. Now the link does not load any styles for the left site example. As for your suggestions, thanks, but we are already minifying the exported css and js files. Sincerely, Hella
Mark Holland
Mark Holland posted this 22 March 2017
Hi Hella,
I have turned the wordporess plugins off and i am still seeing errors which tell me that the java is not minified
https://developers.google.com/speed/pagespeed/insights/?url=https%3A%2F%2Fyoursocialmediamanager.co.uk%2F&tab=mobile
Here are the errors
Consider Fixing:
Minify JavaScript
Compacting JavaScript code can save many bytes of data and speed up downloading, parsing, and execution time.
Minify JavaScript for the following resources to reduce their size by 46.4KiB (44% reduction).
Minifying https://yoursocialmediamanager.co.uk/…SocialMedMan140317/jquery.js?ver=1.0.881 could save 41.3KiB (50% reduction) after compression.
Minifying https://yoursocialmediamanager.co.uk/…SocialMedMan140317/script.js?ver=1.0.881 could save 4.4KiB (22% reduction) after compression.
Minifying https://yoursocialmediamanager.co.uk/…ialMedMan140317/CloudZoom.js?ver=1.0.881 could save 819B (23% reduction) after compression.
Hide details
Hi Hella, I have turned the wordporess plugins off and i am still seeing errors which tell me that the java is not minified https://developers.google.com/speed/pagespeed/insights/?url=https%3A%2F%2Fyoursocialmediamanager.co.uk%2F&tab=mobile Here are the errors Consider Fixing: Minify JavaScript Compacting JavaScript code can save many bytes of data and speed up downloading, parsing, and execution time. Minify JavaScript for the following resources to reduce their size by 46.4KiB (44% reduction). Minifying https://yoursocialmediamanager.co.uk/…SocialMedMan140317/jquery.js?ver=1.0.881 could save 41.3KiB (50% reduction) after compression. Minifying https://yoursocialmediamanager.co.uk/…SocialMedMan140317/script.js?ver=1.0.881 could save 4.4KiB (22% reduction) after compression. Minifying https://yoursocialmediamanager.co.uk/…ialMedMan140317/CloudZoom.js?ver=1.0.881 could save 819B (23% reduction) after compression. Hide details Regards
Support Team posted this 23 March 2017
The site should be using the script.min.js version of the script.js file. As for the others, indeed, they are not minified. Maybe you could find some other plug-in that won't change the CSS files while minifying.
Hi, The site should be using the script.min.js version of the script.js file. As for the others, indeed, they are not minified. Maybe you could find some other plug-in that won't change the CSS files while minifying. Sincerely, Hella
Mark Holland
Mark Holland posted this 23 March 2017
I'm not using the plugin ypu told me themler minify's but it does seem to be working all plugin are off.
Support Team posted this 24 March 2017
Hello Mark,
Themler minifies the "main" files but not all.
For now we may recommend that you consider using special WP plugins which are used to minify JS and CSS code, for example https://wordpress.org/plugins/bwp-minify/, https://wordpress.org/plugins/wp-minify-fix/
I'll also contact developers about script.js file and will let you know
Hello Mark, Themler minifies the "main" files but not all. For now we may recommend that you consider using special WP plugins which are used to minify JS and CSS code, for example https://wordpress.org/plugins/bwp-minify/, https://wordpress.org/plugins/wp-minify-fix/ I'll also contact developers about script.js file and will let you know Regards, Aileen
Mark Holland
Mark Holland posted this 24 March 2017
ok thanks, I think themler really needs to think about optimization addons, like minify correctly and image optimization. The less addons dev's can use the more appealing themler will become.
ok thanks, I think themler really needs to think about optimization addons, like minify correctly and image optimization. The less addons dev's can use the more appealing themler will become. Thanks
Support Team posted this 28 March 2017
Hello Mark,
I contacted developers about this issue and they reported that Themler theme should be loaded with style.min.css and bootstrap.min.css files. The rest .js and .css files are not minified. This should happen after theme is Published
Please try to publish and let us know the results.
Hello Mark, I contacted developers about this issue and they reported that Themler theme should be loaded with style.min.css and bootstrap.min.css files. The rest .js and .css files are not minified. This should happen after theme is Published !publish.png! Please try to publish and let us know the results. regards, Aileen
