Google Adword flagged my site as having malware
estephan
estephan posted this 20 March 2017
I have several clients using Google Adwords and all have been flagged as having MAlware ?!
I have removed the theme created with Themler and re-added with unchecking the option in export to NOT having Themler included and it seemed to work , However if i deactivate the themler-core I loose all styling ?
Is there a reason for this and is there a work around to have these sites working again without Google flagging them as having Malware?
This has now become an issue and a fix maybe in order hopefully soon.
I have several clients using Google Adwords and all have been flagged as having MAlware ?! I have removed the theme created with Themler and re-added with unchecking the option in export to NOT having Themler included and it seemed to work , However if i deactivate the themler-core I loose all styling ? Is there a reason for this and is there a work around to have these sites working again without Google flagging them as having Malware? This has now become an issue and a fix maybe in order hopefully soon.
Support Team posted this 22 March 2017
Hello Estephan,
please provide more details about the issue:
1.please provide link to one of your sites which demonstrates the issue;
2.if possible please provide result of Google check (screenshot or link)
The Themler Core plugin and 'Include Themler' export option are not the same. 'Include Themler' option allows to open and edit the theme in Themler, so you see the Themler menu in the WP admin menu.
The Themler Core plugin handles with Themler shortcodes. If it is disabled the shortcodes are not interpreted.
Hello Estephan, please provide more details about the issue: 1.please provide link to one of your sites which demonstrates the issue; 2.if possible please provide result of Google check (screenshot or link) The Themler Core plugin and 'Include Themler' export option are not the same. 'Include Themler' option allows to open and edit the theme in Themler, so you see the Themler menu in the WP admin menu. The Themler Core plugin handles with Themler shortcodes. If it is disabled the shortcodes are not interpreted. regards, Aileen
estephan
estephan posted this 30 March 2017
Hi thanks for the reply , but I don't know what google Awords team are picking up but it seems that when I remove the option to not include Themler Option in my imported theme its clear of malware and I believe its a false positive due to the fact that Themler links to external source to be able to edit the theme in Wordpress Admin , in any case I kept the Themler core plugin and all works fine which means any changes to the theme I have to do locally and re-import to wordpress.
Support Team posted this 31 March 2017
Indeed, the result looks like false positive. You can also try to contact Google support so they will consider Themler editor as a clear extension.
Hi, Indeed, the result looks like false positive. You can also try to contact Google support so they will consider Themler editor as a clear extension. Sincerely, Hella
