more-tag styling
Porrey
Porrey posted this 20 March 2017
Hey, I want to style "more-tag" in wordpress which appears when you create a new blogpost and add the "more-tag". Normally you can add a text with <!--more Lorem ipsum--> but with a Themler template you can't.
How can I style this?
Hey, I want to style "more-tag" in wordpress which appears when you create a new blogpost and add the "more-tag". Normally you can add a text with &lt;!--more Lorem ipsum--&gt; but with a Themler template you can't. How can I style this?
Support Team posted this 21 March 2017
Please make sure that you added ReadMore control to the Blog Template under the Posts control >> Add Control in Themler:
Hi, Please make sure that you added ReadMore control to the Blog Template under the Posts control >> Add Control in Themler: !add-readmore.png! Thank you, Olivia
Porrey
Porrey posted this 21 March 2017
Thanks for the answer, but the problem still exists. Cause if I add the control "Post Read More" the [...] still appears. It adds just a button
That tag can be removed from the WP admin >> Appearance >> Theme Options >> Excerpt >> Show More link. Disable that option and it will remove the WP more tag and leave the Themler button only.
Hi, That tag can be removed from the WP admin >> Appearance >> Theme Options >> Excerpt >> Show More link. Disable that option and it will remove the WP more tag and leave the Themler button only. Sincerely, Hella
