no instal
adis168
adis168 posted this 21 March 2017
No install Please wait...Themler Diagnostics Log
Please create a new support topic at 'http://answers.themler.com' and attach this log to your ticket.
Bad https://snag.gy/zm08Bd.jpg
No install Please wait...Themler Diagnostics Log Please create a new support topic at 'http://answers.themler.com' and attach this log to your ticket. Bad https://snag.gy/zm08Bd.jpg
adis168
Szczegółowe informacje na temat wywoływania debugowania w trybie JIT (just in time)
zamiast tego okna dialogowego znajdują się na końcu tego komunikatu.
********** Tekst wyjątku **********
System.IO.FileNotFoundException: Nie można odnaleźć pliku 'C:\Program Files (x86)\Themler\diagnostics.info'.
Nazwa pliku: 'C:\Program Files (x86)\Themler\diagnostics.info'
w System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
w System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
w System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
w System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
w System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize)
w System.IO.StreamReader..ctor(String path, Encoding encoding)
w System.IO.File.ReadAllText(String path, Encoding encoding)
w ThemlerDiagnostics.Settings.GetThemlerPaths()
w ThemlerDiagnostics.Diagnostics.GetVersions()
w ThemlerDiagnostics.Diagnostics.Run()
w System.Windows.Forms.Form.OnShown(EventArgs e)
w System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
w System.Threading.ExecutionContext.runTryCode(Object userData)
w System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
w System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
w System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
w System.Windows.Forms.Control.InvokeMarshaledCallbacks()
********** Zestawy załadowane **********
mscorlib
Wersja zestawu: 2.0.0.0
Wersja Win32: 2.0.50727.5485 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
mscorlib.resources
ThemlerDiagnostics
Wersja zestawu: 1.0.0.0
Wersja Win32: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Themler/bin/diagnostics/ThemlerDiagnostics.exe
Wersja Win32: 2.0.50727.5491 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Wersja Win32: 2.0.50727.8686 (QFE.050727-8600)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Wersja Win32: 2.0.50727.5495 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Windows.Forms.resources
Wersja Win32: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_pl_b77a5c561934e089/System.Windows.Forms.resources.dll
********** Debugowanie w trybie JIT **********
Aby włączyć debugowanie w trybie JIT (just-in-time), plik .config tej
aplikacji lub komputera (machine.config) musi mieć
wartość jitDebugging ustawioną w sekcji system.windows.forms.
Aplikacja musi być również skompilowana z włączonym
debugowaniem.
Na przykład:
<configuration>
<system.windows.forms jitDebugging="true" />
Gdy debugowanie JIT jest włączone, wszystkie nieobsługiwane wyjątki
są wysyłane do debugera JIT zarejestrowanego na komputerze
i nie są obsługiwane w tym oknie dialogowym.
Szczegółowe informacje na temat wywoływania debugowania w trybie JIT (just in time) zamiast tego okna dialogowego znajdują się na końcu tego komunikatu. ************** Tekst wyjątku ************** System.IO.FileNotFoundException: Nie można odnaleźć pliku 'C:\Program Files (x86)\Themler\diagnostics.info'. Nazwa pliku: 'C:\Program Files (x86)\Themler\diagnostics.info' w System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) w System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy) w System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy) w System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) w System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize) w System.IO.StreamReader..ctor(String path, Encoding encoding) w System.IO.File.ReadAllText(String path, Encoding encoding) w ThemlerDiagnostics.Settings.GetThemlerPaths() w ThemlerDiagnostics.Diagnostics.GetVersions() w ThemlerDiagnostics.Diagnostics.Run() w System.Windows.Forms.Form.OnShown(EventArgs e) w System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) w System.Threading.ExecutionContext.runTryCode(Object userData) w System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) w System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) w System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) w System.Windows.Forms.Control.InvokeMarshaledCallbacks() ************** Zestawy załadowane ************** mscorlib Wersja zestawu: 2.0.0.0 Wersja Win32: 2.0.50727.5485 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- mscorlib.resources Wersja zestawu: 2.0.0.0 Wersja Win32: 2.0.50727.5485 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- ThemlerDiagnostics Wersja zestawu: 1.0.0.0 Wersja Win32: 1.0.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/Themler/bin/diagnostics/ThemlerDiagnostics.exe ---------------------------------------- System.Windows.Forms Wersja zestawu: 2.0.0.0 Wersja Win32: 2.0.50727.5491 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Wersja zestawu: 2.0.0.0 Wersja Win32: 2.0.50727.8686 (QFE.050727-8600) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Wersja zestawu: 2.0.0.0 Wersja Win32: 2.0.50727.5495 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Windows.Forms.resources Wersja zestawu: 2.0.0.0 Wersja Win32: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_pl_b77a5c561934e089/System.Windows.Forms.resources.dll ---------------------------------------- ************** Debugowanie w trybie JIT ************** Aby włączyć debugowanie w trybie JIT (just-in-time), plik .config tej aplikacji lub komputera (machine.config) musi mieć wartość jitDebugging ustawioną w sekcji system.windows.forms. Aplikacja musi być również skompilowana z włączonym debugowaniem. Na przykład: &lt;configuration&gt; <system.windows.forms jitDebugging="true" /> Gdy debugowanie JIT jest włączone, wszystkie nieobsługiwane wyjątki są wysyłane do debugera JIT zarejestrowanego na komputerze i nie są obsługiwane w tym oknie dialogowym.
Support Team posted this 21 March 2017
Please try to reinstall the application and the suggestions from this article:
http://answers.themler.com/articles/13879/themler-desktop-troubleshooting
Hi, Please try to reinstall the application and the suggestions from this article: http://answers.themler.com/articles/13879/themler-desktop-troubleshooting Sincerely, Hella
