Edit text in columns
info842
info842 posted this 21 March 2017
I inserted a section to a page in Themler. The sections contains columns. I added text controls to these columns and input some text. But after that I try to make changes to the text but I cant! I cant double click or what to edit the text. I can change it in just 1 column not in the other ones. When I go to the other ones the mouse pointer change in a white cross or something.
Please help
I inserted a section to a page in Themler. The sections contains columns. I added text controls to these columns and input some text. But after that I try to make changes to the text but I cant! I cant double click or what to edit the text. I can change it in just 1 column not in the other ones. When I go to the other ones the mouse pointer change in a white cross or something. Please help
info842
Please help
I think I solved it. I placed the section outside the cms content and now its fine.
> I inserted a section to a page in Themler. The sections contains columns. I added text controls to these columns and input some text. But after that I try to make changes to the text but I cant! I cant double click or what to edit the text. I can change it in just 1 column not in the other ones. When I go to the other ones the mouse pointer change in a white cross or something. > > Please help I think I solved it. I placed the section outside the cms content and now its fine.
Support Team posted this 22 March 2017
Ok. Great!
Please let us know if you need our further assistance here.
Hi, Ok. Great! Please let us know if you need our further assistance here. Thank you, Olivia
info842
info842 posted this 23 March 2017
This is not ok...
It didnt work inside the cms content so I put it out of the cms content and it worked fine but now the problem is that on every page in WP the sections with columns are visable.
Please help me to assign the sections to only that page ond not to the page template!
This is not ok... It didnt work inside the cms content so I put it out of the cms content and it worked fine but now the problem is that on every page in WP the sections with columns are visable. Please help me to assign the sections to only that page ond not to the page template! Regards
Support Team posted this 23 March 2017
Hello Richard,
if you want a Control to be located on certain page only it should be located inside CMS Content, in area with green border.
In your case a control is saved as part of template and thus it is displayed on all pages which are based on this template.
You need to moved control inside green area.
Hello Richard, if you want a Control to be located on certain page only it should be located inside CMS Content, in area with green border. In your case a control is saved as part of template and thus it is displayed on all pages which are based on this template. You need to moved control inside green area. Regards, Aileen
