Language Wordpress
Linkebel
Linkebel posted this 26 May 2015
I, unwanted language plugin WPML
https://wpml.org/
How releir the plugin with the language of themler selection?
Hello, I, unwanted language plugin WPML https://wpml.org/ How releir the plugin with the language of themler selection?
12 Comments
Support Team posted this 26 May 2015
On WordPress sites when new language is selected using the Themler Language control the "lang" attribute in tag is updated with the selected language value
<html dir="ltr" lang="de-DE">
and "language" cookie is created
language="de_DE"
Unfortunately the Language control does not work with third-party WP localization plug-ins.
The rest of the theme should work with localization plug-ins as any other WP theme.
Hello On WordPress sites when new language is selected using the Themler Language control the "lang" attribute in <html> tag is updated with the selected language value `<html dir="ltr" lang="de-DE">` and "language" cookie is created `language="de_DE"` Unfortunately the Language control does not work with third-party WP localization plug-ins. The rest of the theme should work with localization plug-ins as any other WP theme. Thank you, Olivia
Linkebel
Linkebel posted this 27 May 2015
OK thank you
It would be nice that in future we can link it to a plugin ;-)
OK thank you It would be nice that in future we can link it to a plugin ;-)
Support Team posted this 27 May 2015
thank you for your suggestion, it is already in our wish list, but it is not planned for the near future.
Hello, thank you for your suggestion, it is already in our wish list, but it is not planned for the near future. Regards, Aileen
Pixel Web Serv
Pixel Web Serv posted this 14 January 2017
so after an year from latest response, Themler is compatible with any multi language plugin?
Hello, so after an year from latest response, Themler is compatible with any multi language plugin?
Support Team posted this 17 January 2017
Themler themes are working with WP multi language plugins.
In case you get a problem with one of them please describe the issue in details.
Hello, Themler themes are working with WP multi language plugins. In case you get a problem with one of them please describe the issue in details. Regards, Aileen
DFG
DFG posted this 23 February 2017
Hi!
While almost desperately searching for a solution on Language control issue with WP multilanguage plugin, I am posting video about it here: http://screencast-o-matic.com/watch/cbn3rF6bNx, hoping to get a support.
If Themler found this reply as duplicate, feel free to delete it after help resolve it on another answer.
dfg
Hi! While almost desperately searching for a solution on Language control issue with WP multilanguage plugin, I am posting video about it here: http://screencast-o-matic.com/watch/cbn3rF6bNx, hoping to get a support. If Themler found this reply as duplicate, feel free to delete it after help resolve it on another answer. Regards, dfg
Support Team posted this 24 February 2017
language="de_DE"
This is behaviour by default. It's enough in most of cases.
Themler Language control does not add URL parameters as the other language switcher do in your video.
Hi, On WordPress sites when new language is selected using the Themler Language control the "lang" attribute in tag is updated with the selected language value `<html dir="ltr" lang="de-DE">` and "language" cookie is created `language="de_DE"` This is behaviour by default. It's enough in most of cases. Themler Language control does not add URL parameters as the other language switcher do in your video. Thank you, Olivia
DFG
DFG posted this 24 February 2017
Thank you very much for your answer!
So what is the function of Themler Language control if it is not able to switch website's language?
What behavior is it expected from cookie creation and URL with # sign?
You can see in my video that Themler Language control is effected when language is switched with other language switcher (wp plugin), but opossite - switching languages with Themler Language control is not working.
dfg
Thank you very much for your answer! So what is the function of Themler Language control if it is not able to switch website's language? What behavior is it expected from cookie creation and URL with # sign? You can see in my video that Themler Language control is effected when language is switched with other language switcher (wp plugin), but opossite - switching languages with Themler Language control is not working. regards, dfg
Support Team posted this 27 February 2017
Are you working with WP 4.7?
Usually, the page should be refreshed when you switch languages. It does not work on WP 4.7 on my side. I'll ask our developers about this issue.
Hi, Are you working with WP 4.7? Usually, the page should be refreshed when you switch languages. It does not work on WP 4.7 on my side. I'll ask our developers about this issue. Thank you, Olivia
DFG
DFG posted this 28 February 2017
Yes, working with WordPress 4.7.2
"the page should be refreshed when you switch languages"...
To clarify: when a multilanguage plugin is set, and Themler Language control is used to switch language, than page should refresh ?
If an answer is yes, it is pretty obvious to expect that, but was not experienced so.
I hope to hear soon from your developers.
Thank you!
dfg
PS: it does not look version dependent issue. Have just the same issue on WP 4.6.3 and Themler 1.0.556
Yes, working with WordPress 4.7.2 "the page should be refreshed when you switch languages"... To clarify: when a multilanguage plugin is set, and Themler Language control is used to switch language, than page should refresh ? If an answer is yes, it is pretty obvious to expect that, but was not experienced so. I hope to hear soon from your developers. Thank you! Regards, dfg PS: it does not look version dependent issue. Have just the same issue on WP 4.6.3 and Themler 1.0.556
Support Team posted this 01 March 2017
yes, the page should reload and language should change.
Lets wait developers response.
Hello, yes, the page should reload and language should change. Lets wait developers response. regards, Aileen
alexarafatonline
alexarafatonline posted this 01 November 2025
It sounds like you're dealing with a language plugin conflict. To resolve this with WPML, you’ll need to check the language settings in your theme and make sure they’re properly integrated with WPML’s language options. In WPML settings, you can assign the correct language per page or post, ensuring that the plugin doesn’t cause issues with your theme selection. Once configured, the plugin should work seamlessly with your language preferences. By the way, I’ve been exploring iCalculadoraOnline recently—it's like a hidden gem for quick calculations, from health metrics to financial tools, all in one place!
It sounds like you're dealing with a language plugin conflict. To resolve this with WPML, you’ll need to check the language settings in your theme and make sure they’re properly integrated with WPML’s language options. In WPML settings, you can assign the correct language per page or post, ensuring that the plugin doesn’t cause issues with your theme selection. Once configured, the plugin should work seamlessly with your language preferences. By the way, I’ve been exploring [iCalculadoraOnline][1] recently—it's like a hidden gem for quick calculations, from health metrics to financial tools, all in one place! [1]: https://icalculadoraonline.com.br/
