CSS for category menu in Woocommerce
hovmedia
hovmedia posted this 27 March 2017
Hello!
I am using Themler to create design for a webshop created in Woocommerce. It works great, but I have some problems with the vertical "Product Category Menu". I use the widget that comes with Woocommerce and it looks terible. The menu comes up as a bullet-list. I would like to add the vertical menu CSS from Themler.
Any advices on how to do it? URL: http://dinturbutikk.no/butikk/
Hello! I am using Themler to create design for a webshop created in Woocommerce. It works great, but I have some problems with the vertical "Product Category Menu". I use the widget that comes with Woocommerce and it looks terible. The menu comes up as a bullet-list. I would like to add the vertical menu CSS from Themler. Any advices on how to do it? URL: http://dinturbutikk.no/butikk/
14 Comments
Support Team posted this 27 March 2017
Hi.
Themler vertical menu style can be applied to the Vertical Menu widget only. To output product categories in the vertical menu please add VM widget and select appropriate source:
Hi. Themler vertical menu style can be applied to the Vertical Menu widget only. To output product categories in the vertical menu please add VM widget and select appropriate source: !vm-prod-cat.png! Thank you, Olivia
hovmedia
I can not see "Porduct Categories" as a menu option. I know I manually can create one, but I would like to avoid it to make it easier for others to update site.
hovmedia
Coorection. I found it in the "Vertical menu" widget. Thanks! :)
Seagull
Seagull posted this 03 July 2017
Can you please tell me if there is anyway to style the product categories drop down widget menu for woocommerce? The one that it is Hovmedia's first example?
I don't have room for a fully expanded vertical menu so am using the widget in my sidebar with the dropdown option and the client has requested that the parent categories be listed in bold but I cannot find any setting for it.
Thank you and best regards,
Angela
Hello, Can you please tell me if there is anyway to style the product categories drop down widget menu for woocommerce? The one that it is Hovmedia's first example? I don't have room for a fully expanded vertical menu so am using the widget in my sidebar with the dropdown option and the client has requested that the parent categories be listed in bold but I cannot find any setting for it. Thank you and best regards, Angela
Support Team posted this 04 July 2017
Unfortunately there is no option to make it in Themler. But you can style them manually using custom css. for example:
#dropdown_product_cat .level-0
font-weight: bold;
Custom css can be added to Themler Settings >> Additional CSS.
Hi, Unfortunately there is no option to make it in Themler. But you can style them manually using custom css. for example: `#dropdown_product_cat .level-0 { font-weight: bold; }` Custom css can be added to Themler Settings >> Additional CSS. Thank you, Olivia
Seagull
Seagull posted this 05 July 2017
Thank you Olivia, I'll try that :-)
Seagull
Hi again Olivia,
unfortunately I tried that css but even with !important statement it didn't have any effect. Could anything else be effecting it?
Best regards,
Angela
Hi again Olivia, unfortunately I tried that css but even with !important statement it didn't have any effect. Could anything else be effecting it? Best regards, Angela
Support Team posted this 06 July 2017
We need a live link to the page with the issue to say what may cause it.
The provided solution works ok on my side:
Hi, We need a live link to the page with the issue to say what may cause it. The provided solution works ok on my side: !product-categories-2.png! Thank you, Olivia
Seagull
Seagull posted this 06 July 2017
Thank you but the website is behind a coming soon plugin and not accessible at the moment until launch, can I possibly make a new private thread and send you the theme instead please?
Best regards,
Angela
Thank you but the website is behind a coming soon plugin and not accessible at the moment until launch, can I possibly make a new private thread and send you the theme instead please? Best regards, Angela
Please create a new private topic and provide the access to the admin panel. The theme will not help without website front end.
Hi, Please create a new private topic and provide the access to the admin panel. The theme will not help without website front end. Thank you, Olivia
eja.ge.r.m
eja.ge.r.m posted this 12 April 2025
Improved behavior also contributes to the cat's overall well-being. A Ragdoll that feels secure, loved, and mentally stimulated is less likely to develop health problems related to stress this article. Finally, the process of addressing these issues teaches owners more about feline psychology and helps them become more attentive, compassionate caretakers—not just for Ragdolls, but for any pets they may have in the future.
Improved behavior also contributes to the cat's overall well-being. A Ragdoll that feels secure, loved, and mentally stimulated is less likely to develop health problems related to stress [this article][1]. Finally, the process of addressing these issues teaches owners more about feline psychology and helps them become more attentive, compassionate caretakers—not just for Ragdolls, but for any pets they may have in the future. [1]: https://cattoza.com/ragdoll-cat-behavior-problems/
petterroch77
petterroch77 posted this 07 October 2025
Γεια σου! Εγώ είχα παρόμοιο πρόβλημα με το να βρω κάτι ενδιαφέρον για να ξεφύγω από δουλειά μπροστά από υπολογιστή και τυχαία ανακάλυψα το spinogambino . Αρχικά είχα μερικές μικρές απώλειες, αλλά μετά τόλμησα λίγο παραπάνω σε ένα φρουτάκι και κέρδισα ένα ωραίο ποσό. Οι ειδικές προσφορές για παίκτες από την Ελλάδα έκαναν όλη την εμπειρία ακόμα πιο διασκεδαστική και τώρα είναι η αγαπημένη μου μέθοδος για να χαλαρώνω μετά από τεχνικά προβλήματα και ώρες μπροστά από τον υπολογιστή.
Γεια σου! Εγώ είχα παρόμοιο πρόβλημα με το να βρω κάτι ενδιαφέρον για να ξεφύγω από δουλειά μπροστά από υπολογιστή και τυχαία ανακάλυψα το [spinogambino][1] . Αρχικά είχα μερικές μικρές απώλειες, αλλά μετά τόλμησα λίγο παραπάνω σε ένα φρουτάκι και κέρδισα ένα ωραίο ποσό. Οι ειδικές προσφορές για παίκτες από την Ελλάδα έκαναν όλη την εμπειρία ακόμα πιο διασκεδαστική και τώρα είναι η αγαπημένη μου μέθοδος για να χαλαρώνω μετά από τεχνικά προβλήματα και ώρες μπροστά από τον υπολογιστή. [1]: https://spinogambino.gr
mejov57740
mejov57740 posted this 01 November 2025
Stress is a natural response that arises when life’s pressures start to feel overwhelming, often affecting both the mind and body. It can lead to fatigue, mood swings, and difficulty concentrating, creating a cycle that feels hard to break. However, there’s a chance that finding healthy coping methods, balanced routines, and possible anxiety medication releaf could help ease the tension and bring a sense of calm. Small lifestyle shifts, mindful breathing, and emotional support might open the door to greater peace and resilience over time.
Stress is a natural response that arises when life’s pressures start to feel overwhelming, often affecting both the mind and body. It can lead to fatigue, mood swings, and difficulty concentrating, creating a cycle that feels hard to break. However, there’s a chance that finding healthy coping methods, balanced routines, and possible [anxiety medication releaf][1] could help ease the tension and bring a sense of calm. Small lifestyle shifts, mindful breathing, and emotional support might open the door to greater peace and resilience over time. [1]: https://anxiety-medicationreleaf.co.uk/
