Top Nav Bar - Force text on to new line
TSMM
TSMM posted this 27 May 2015
Is it possible to force longer menu titles to wrap when shown in the top nav bar?
Similar to http://www.standrewscollege.edu.au/
Is it possible to force longer menu titles to wrap when shown in the top nav bar? Similar to http://www.standrewscollege.edu.au/
22 Comments
Stagger Lee posted this 27 May 2015
Try to increase left-right padding around links.
In this URL all menu items are with different widths. And is not done by theme, but by developer manually, Theme cannot guess what words will be in menu items.
Something I doubt Themler will ever be able to do. But you can make the same manually. Now you can add custom classes to menu items.
In this URL all menu items are with different widths. And is not done by theme, but by developer manually, Theme cannot guess what words will be in menu items. Something I doubt Themler will ever be able to do. But you can make the same manually. Now you can add custom classes to menu items.
Support Team posted this 27 May 2015
the text of menu items may be split into two or more lines using combination of Themler settings and custom CSS code. Here is an example applied to default Themler theme:
1. open Menu tab of Horizontal Menu control and open Arrange. There set Max width to desired value and set 'White-space' option to "pre", e.g.:
2.in addition to it add the following CSS code under Settings >> Additional CSS
.bd-menu-3.nav-pills .bd-menuitem-3 > a, .bd-menu-3.nav-pills .bd-menuitem-3 > a:link, .bd-menu-3.nav-pills .bd-menuitem-3 > a:visited{
  word-break: break-word;
Hello, the text of menu items may be split into two or more lines using combination of Themler settings and custom CSS code. Here is an example applied to default Themler theme: 1. open Menu tab of Horizontal Menu control and open Arrange. There set Max width to desired value and set 'White-space' option to "pre", e.g.: !ItemWidth.png! 2.in addition to it add the following CSS code under Settings >> Additional CSS .bd-menu-3.nav-pills .bd-menuitem-3 > a, .bd-menu-3.nav-pills .bd-menuitem-3 > a:link, .bd-menu-3.nav-pills .bd-menuitem-3 > a:visited{ word-break: break-word; } Regards, Aileen
DaveOzric
DaveOzric posted this 01 March 2016
Nice!
However I did this in the Desktop version in a HTML5 site without the custom css. Has this changed in newer versions?
How do I make all the menu items the same height and center the text vertically?
Nice! However I did this in the Desktop version in a HTML5 site without the custom css. Has this changed in newer versions? How do I make all the menu items the same height and center the text vertically? !2016-03-01-111433.jpg! Thanks
Support Team posted this 02 March 2016
You can try setting Item's Height, however, the vertical align is not yet adjustable.
Thank you!
You can try setting Item's Height, however, the vertical align is not yet adjustable. Thank you!
DaveOzric
DaveOzric posted this 16 March 2016
Any chance it will be an option in a new version?
lesergei
lesergei posted this 16 March 2016
I'd like to see this feature in an upcoming update. But it would be much simpler if we could add a code directly into the CMS.
Hello, I'd like to see this feature in an upcoming update. But it would be much simpler if we could add a code directly into the CMS. Thank you
DaveOzric
I can't get this to work anymore. Can you please verify and give new instructions?
Stagger Lee posted this 16 March 2016
Themler menu Walker is very specific and customized. Dont go there and think you can easy replace Themler menu with custom PHP code. You will get very basic menu and all styling you have to do self.
> Hello, > > I'd like to see this feature in an upcoming update. But it would be much simpler if we could add a code directly into the CMS. > > Thank you Themler menu Walker is very specific and customized. Dont go there and think you can easy replace Themler menu with custom PHP code. You will get very basic menu and all styling you have to do self.
lesergei
My code was missing of the message, I meant this code /br.
Hi, My code was missing of the message, I meant this code /br.
Support Team posted this 21 March 2016
Hello guys!
I've added relevant suggestion to our wish list and it will be considered for the future versions.
Hello guys! I've added relevant suggestion to our wish list and it will be considered for the future versions. Regards, Aileen
here is updated solution for current Themler version
1.no additional custom CSS;
2.open Horizontal Menu >> Menu Item options and set
Width
Height
White-space: pre-line
Hello, here is updated solution for current Themler version 1.no additional custom CSS; 2.open Horizontal Menu >> Menu Item options and set Width Height White-space: pre-line !MenuWrap.png! Regards, Aileen
DaveOzric
DaveOzric posted this 19 September 2017
Hello, back to this again, the solution works but is it possible to center the text vertically? It looks weird aligned to the top.
Hello, back to this again, the solution works but is it possible to center the text vertically? It looks weird aligned to the top. Thank you
Support Team posted this 20 September 2017
Have you tried the Vertical Align option for the menu item? If that does not help, provide your theme exported with the content and editor included.
Hi, Have you tried the Vertical Align option for the menu item? If that does not help, provide your theme exported with the content and editor included. Sincerely, Hella
DaveOzric
DaveOzric posted this 20 September 2017
Hello, I would try this but have not seen such a setting. Can you provide instructions on where this is?
Support Team posted this 21 September 2017
I meant the Vertical Align option as on the screen shot several messages above:
enter image description here
It's in the right bottom corner.
Hi, I meant the Vertical Align option as on the screen shot several messages above: ![enter image description here][1] It's in the right bottom corner. Sincerely, Hella [1]: http://forumattachments.themler.io/310/12310/MenuWrap.png
DaveOzric
DaveOzric posted this 21 September 2017
Doesn't work for me. There are some requirements in the vertical align settings I don't understand.
Doesn't work for me. There are some requirements in the vertical align settings I don't understand. !2017-09-21-102525.jpg!
Support Team posted this 22 September 2017
Please export your theme with the content and editor included and attach it to the ticket, we'll look into the settings.
Hi, Please export your theme with the content and editor included and attach it to the ticket, we'll look into the settings. Sincerely, Hella
DaveOzric
DaveOzric posted this 22 September 2017
DaveOzric
DaveOzric posted this 26 September 2017
Any word on this?
Any word on this?
