Top Nav Bar - Force text on to new line
TSMM
TSMM posted this 27 May 2015
Is it possible to force longer menu titles to wrap when shown in the top nav bar?
Similar to http://www.standrewscollege.edu.au/
Is it possible to force longer menu titles to wrap when shown in the top nav bar? Similar to http://www.standrewscollege.edu.au/
22 Comments
DaveOzric
DaveOzric posted this 27 September 2017
Guess you are only working on upage now days. :(
Support Team posted this 27 September 2017
As I can see the alignment of the menu items works the same as in the provided example.
The easiest way to achieve the alignment you want is custom css. For example:
.bd-menu-1
display: flex;
display: -webkit-flex; /* Safari */
display: -ms-flexbox; /* IE 10 */
align-items: center;
-webkit-align-items: center;
Unfortunately Themler does not provide additional flexbox settings. Therefore you cannot set align-items property in Themler directly.
Another simple solution is:
.bd-menu-1.nav-pills > .bd-menuitem-1{
float: none;
display: table-cell;
vertical-align: middle;
Hi, As I can see the alignment of the menu items works the same as in the provided example. The easiest way to achieve the alignment you want is custom css. For example: `.bd-menu-1 { display: flex; display: -webkit-flex; /* Safari */ display: -ms-flexbox; /* IE 10 */ align-items: center; -webkit-align-items: center; }` Unfortunately Themler does not provide additional flexbox settings. Therefore you cannot set align-items property in Themler directly. Another simple solution is: `.bd-menu-1.nav-pills > .bd-menuitem-1{ float: none; display: table-cell; vertical-align: middle; }` Thank you, Olivia
