Header "Show on Template"
BeatM
BeatM posted this 29 March 2017
Hi again,
I am not able to activate/deactivate the control for Header (all Templates).
Somehow I was able to deactivate it on a page, but now I can not reactivate.
How to use this properly?
Beat
Hi again, I am not able to activate/deactivate the control for Header (all Templates). Somehow I was able to deactivate it on a page, but now I can not reactivate. How to use this properly? Thanks Beat
Support Team posted this 29 March 2017
You can enable/disable the Header for a specific template/templates in the Insert tab:
Alternatively, you can set this in the Header tab that will be opened if you select Header on any of the templates where it is enabled.
Hello, You can enable/disable the Header for a specific template/templates in the Insert tab: !i449.png! Alternatively, you can set this in the Header tab that will be opened if you select Header on any of the templates where it is enabled. Sincerely, Nettie, BillionDigital Team
BeatM
Thanks Nettie !
Thanks Nettie !
You are welcome. Feel free to contact us again.
You are welcome. Feel free to contact us again. Sincerely, Hella
