After opening themler, and importing a theme from billionthemes.com the software crashes.
It doesn't matter if you use v349 or v364. It happens with both.
We get the white popup with: "127.0.0.1:12080 reports the following: Sorry, error occured. Your project will be restored."
The last part is just a joke.
It will get you in a loop, and nothing will work anymore.
Even if you download a theme from billionthemes.com, and want to open it in Themer it gives you the same error
After opening themler, and importing a theme from billionthemes.com the software crashes. It doesn't matter if you use v349 or v364. It happens with both. We get the white popup with: "127.0.0.1:12080 reports the following: Sorry, error occured. Your project will be restored." The last part is just a joke. It will get you in a loop, and nothing will work anymore. Even if you download a theme from billionthemes.com, and want to open it in Themer it gives you the same error
