Please clarify "Made with Artisteer" vs. "Made with Themeler"
sonicthoughts
sonicthoughts posted this 28 May 2015
I see only 9 drupal templates made with themeler but 890 with Artisteer. What are the limitations/differences? Also, if in Artisteer I could create a theme in Wordpress and then apply to Drupal - does this work the same in themeler?
Support Team posted this 29 May 2015
The themes exported with Artisteer will act like other Artisteer themes, they do have different design and a bit different structure compared with the Themler themes. It's better to try one to see the difference.
Also to change the type of Artisteer template you will need to find the according .artx file, open it in Artisteer and then export to one of the supported CMSs. Such option is not possible in Themler now. Maybe it will be implemented in the future updates, but I can't provide you with any information about that.
Also note that when using Artisteer theme you can not simply open the editor from the .zip theme you have like it is done in Themler, you will need to open the appropriate .artx file in the application and then export the .zip theme once again.
Hi, The themes exported with Artisteer will act like other Artisteer themes, they do have different design and a bit different structure compared with the Themler themes. It's better to try one to see the difference. Also to change the type of Artisteer template you will need to find the according .artx file, open it in Artisteer and then export to one of the supported CMSs. Such option is not possible in Themler now. Maybe it will be implemented in the future updates, but I can't provide you with any information about that. Also note that when using Artisteer theme you can not simply open the editor from the .zip theme you have like it is done in Themler, you will need to open the appropriate .artx file in the application and then export the .zip theme once again. Sincerely, Hella BillionDigital Team
