how to place 1 collumn + seperator + collumn in a article
arawolf
arawolf posted this 06 April 2017
I want to change a article ( joomla site ) in the page template; So a make a menu item, linked to a article and try to change it in themler. But in the article i can only input a section and 1 collumn; But i want to input different items to the article. Different collums and in between separators. Can you help me?
I want to put the different separators and collumns in the articles space. Now they are placed outside the article space.
I want to change a article ( joomla site ) in the page template; So a make a menu item, linked to a article and try to change it in themler. But in the article i can only input a section and 1 collumn; But i want to input different items to the article. Different collums and in between separators. Can you help me? I want to put the different separators and collumns in the articles space. Now they are placed outside the article space.
Support Team posted this 07 April 2017
Try to put the Container into the section and the insert other controls within the container.
Hi, Try to put the Container into the section and the insert other controls within the container. Sincerely, Hella
arawolf
arawolf posted this 07 April 2017
i will try
i will try
Let me know if that works. In other case attach your theme exported with the editor and content included.
Let me know if that works. In other case attach your theme exported with the editor and content included. Sincerely, Hella
