change menu to sheet widith
jackymoore10
jackymoore10 posted this 08 April 2017
Hi just rebuilding my website after I lost the whole thing. After I have a few questions, as I can't remember how to use themler... its been a while,
1.How do I make the menu sheet width
2. how do I adjust the size all the menu items, so that they are the same width as their sub menu items - looks neater that way.
Hi just rebuilding my website after I lost the whole thing. After I have a few questions, as I can't remember how to use themler... its been a while, 1.How do I make the menu sheet width 2. how do I adjust the size all the menu items, so that they are the same width as their sub menu items - looks neater that way.
24 Comments
Support Team posted this 10 April 2017
Hello Jacky,
1.you may set the length of Horizontal menu to Boxed
2.you may specify the Width for Menu Item
Hello Jacky, 1.you may set the length of Horizontal menu to Boxed !HMenu.png! 2.you may specify the Width for Menu Item !ItemWidth.png! regards, Aileen
jackymoore10
jackymoore10 posted this 10 April 2017
Okay thanks for that tip but it didn't seem to make my menu screen width?
Also how do I centre my sub menus .. so they are like my main menus please
Okay thanks for that tip but it didn't seem to make my menu screen width? Also how do I centre my sub menus .. so they are like my main menus please
jackymoore10
New Question
When I add a section, why does themler add it every other page and not just the page I want to add it too? I remember coming across this pitfall the first time I build my site can you remind why this is? and how to resolve it please? Gosh its like walking through the dark wood all over again and falling in all the same traps. Wish you guys published a book or some online training that was up to date would be sooo helpful. ( im guessing that the soft ware changes so often that it would be out of date and a thankless task).
Any way...back to my question How do I add different sections to each page?
New Question When I add a section, why does themler add it every other page and not just the page I want to add it too? I remember coming across this pitfall the first time I build my site can you remind why this is? and how to resolve it please? Gosh its like walking through the dark wood all over again and falling in all the same traps. Wish you guys published a book or some online training that was up to date would be sooo helpful. ( im guessing that the soft ware changes so often that it would be out of date and a thankless task). Any way...back to my question How do I add different sections to each page?
Support Team posted this 11 April 2017
  1. To center the subitem text go to Horizontal Menu >> Subitem >> Text and choose the desired align icon.
  2. You need to add the section into the green area of the desired page, the green area is the content of the specific page. You might inserted it into the blue area. The blue area is the part of the particular template and all pages using that template will show that section. The orange area is shared on all pages of your site (that is the header, footer and sidebars).
Hi, 1. To center the subitem text go to Horizontal Menu >> Subitem >> Text and choose the desired align icon. 2. You need to add the section into the green area of the desired page, the green area is the content of the specific page. You might inserted it into the blue area. The blue area is the part of the particular template and all pages using that template will show that section. The orange area is shared on all pages of your site (that is the header, footer and sidebars). Sincerely, Hella
jackymoore10
jackymoore10 posted this 11 April 2017
Hi I had this on my last website which I lost do you know which what the Id of this section would be called I have no idea where to start looking in your add sections
jackymoore10
How do I set the headings ?
Ie heading 1
heading 2
Heading 3
bullet 1
and buttons
thanks
How do I set the headings ? Ie heading 1 heading 2 Heading 3 bullet 1 and buttons thanks
Please try these sections:
http://billionthemes.com/Themes/Index?Search.Section=True&Search.RelatedMediaId=2860398
The question about the headings is not clear. You want to define styles for each heading? Do that under the Design tab.
Hi, Please try these sections: http://billionthemes.com/Themes/Index?Search.Section=True&Search.RelatedMediaId=2860398 The question about the headings is not clear. You want to define styles for each heading? Do that under the Design tab. Sincerely, Hella
jackymoore10
I would like to apply heading styles, to set the type face and and font size so that when I add headings they are all the same on each page without having to do it manually.
jackymoore10
On my contact page I have added a section from themler, can you see the GREEN EMAIL BIT, how do i change the colour from green to another colour and up/over and click states for this email? please.
see attached
On my contact page I have added a section from themler, can you see the GREEN EMAIL BIT, how do i change the colour from green to another colour and up/over and click states for this email? please. see attached
jackymoore10
How Do I add a read more link to a page so that I don't have to have the full text on a page.... as you can see from the attached this page text is quite long and would benefit from a 'read more link' at the bottom of the first Paragraph. I don't need it do go to a new page but just EXPAND ON THE SAME PAGE.
Support Team posted this 13 April 2017
Hello Jacky,
1.
Open Design tab >> More styles and there you may configure the settings of Headings. The styles set here will be applied everywhere in theme where Headings are added
2.
Click on the text which options you'd like to change. So corresponding control is selected, open its options and under Text tab change the text color
If you cannot handle with it please provide access to the Joomla admin back end.
3.
The read more tag is added to the article in Joomla. Then in Themler to make this tag working the Post Read More control should be added. It could be done on Blog template.
In your case the Post template is used. The Post Ream More control cannot be added there.
Hello Jacky, 1. > I would like to apply heading styles, to set the type face and and > font size so that when I add headings they are all the same on each > page without having to do it manually. Open Design tab >> More styles and there you may configure the settings of Headings. The styles set here will be applied everywhere in theme where Headings are added !Headings.png! 2. > how do i change the colour from green to another colour Click on the text which options you'd like to change. So corresponding control is selected, open its options and under Text tab change the text color If you cannot handle with it please provide access to the Joomla admin back end. 3. > How Do I add a read more link The read more tag is added to the article in Joomla. Then in Themler to make this tag working the Post Read More control should be added. It could be done on Blog template. In your case the Post template is used. The Post Ream More control cannot be added there. regards, Aileen
jackymoore10
jackymoore10 posted this 14 April 2017
How do I add a read more to in a joomla article?
jackymoore10
How to I add Video in place of an image, I clicked on add video but the video is not connected to the image box, and when I move the section the video gets left behind. Is there a way to add video directly from youtube link. via the add image.
jackymoore10
ok found it, under more, but when I click add video i just get the blue wheel when I click add video and then nothing
jackymoore10
Ok fixed all the above
jackymoore10
except for read more link still need to know how to do that in joomla
jackymoore10
NEW CHALLENGE.. SERVICES MENU, AND MOTION GRAPHICS MENU, not working when I click on them on my mobile , however submenus are can you tell me why this is?
jackymoore10
jackymoore10 posted this 16 April 2017
I tried adding this as html directly into the article but it didn't work can you tell me why?
<html>
<head>
$("button").click(function(){
    $("p").toggle();
<body>
<p>This is a paragraph.</p>
<button>Toggle between hide() and show()</button>
</body>
and adding read more did not work in joomla either what am I doing wrong?
I tried adding this as html directly into the article but it didn't work can you tell me why? &lt;html&gt; &lt;head&gt; $("button").click(function(){ $("p").toggle(); }); }); &lt;body&gt; &lt;p&gt;This is a paragraph.&lt;/p&gt; &lt;button&gt;Toggle between hide() and show()&lt;/button&gt; &lt;/body&gt; and adding read more did not work in joomla either what am I doing wrong?
Support Team posted this 17 April 2017
The read more tag should be inserted inside Joomla when editing the article. Then it should appear. If it does not appear, then open the Blog template inside Themler, open the Posts control options on the top ribbon and use add control >> Read more option and drag it inside the post content area.
We need an access to your site back end to be sure and check the settings. As I can suppose, those menu items do have submenus and under the Horizontal Menu control >>> Mobile Menu >> Submenus option you have Expand on Click option. Choose the Expand with Reload.
Let me know if that helps.
Hi, >read more link still need to know how to do that in joomla The read more tag should be inserted inside Joomla when editing the article. Then it should appear. If it does not appear, then open the Blog template inside Themler, open the Posts control options on the top ribbon and use add control >> Read more option and drag it inside the post content area. >NEW CHALLENGE.. SERVICES MENU, AND MOTION GRAPHICS MENU, not working when I click on them on my mobile , however submenus are can you tell me why this is? We need an access to your site back end to be sure and check the settings. As I can suppose, those menu items do have submenus and under the Horizontal Menu control >>> Mobile Menu >> Submenus option you have Expand on Click option. Choose the Expand with Reload. Let me know if that helps. Sincerely, Hella
jackymoore10
jackymoore10 posted this 18 April 2017
Fixed thankyou
Fixed thankyou
